Please help, Engine Replacement - see video
21 replies to this topic
#16 bhts OFFLINE
bhts
  • 1,456 Thanks
  • 2,154 posts
Posted June 24, 2017 - 10:23 AM
I contacted Sears for a direct replacement, and this is what they sent me... http://www.searspart...mpaign=pd-oc-nb
That explains a lot. Before you get to far into it you may want to check the crank dia and also the bolt fitting from the motor they sent you to the one you have. Briggs shows two different cranks for the engine.
  • Oldford said thank you
#17 MiCarl ONLINE
MiCarl
  • 1,746 Thanks
  • 932 posts
Posted June 24, 2017 - 11:39 AM
If you don't care about the lights you can just leave the orange wire disconnected.
If you want the lights to work (better than factory) put a 7.5A fuse in the orange wire and connect it to the hot post of the solenoid, the same terminal that connects to the battery.
Edited by MiCarl, June 24, 2017 - 11:41 AM.
#18 Skeeter65 OFFLINE
Skeeter65
  • 4 Thanks
  • 11 posts
Posted June 24, 2017 - 12:17 PM
Dang, ran into a snag! The new motor was damaged in shipment (See attached picture, cracked engine cover).  I called sears and they are sending out a new one.  I could install this one and when the new one comes in just swap the cover......Although Im not sure if what caused the engine cover to crack did more damage that I cannot see......
Motor pics
Engine Removed
New Engine
Old Engine
#19 Skeeter65 OFFLINE
Skeeter65
  • 4 Thanks
  • 11 posts
Posted June 24, 2017 - 12:23 PM
Perfect!  Thats what I'm going to do!.
So I think I have determined plugging the red wire from the new engine voltage regulator into the where the old engine red wire (That came from the Stator) is the way to go, and the carb solenoid is plug and play, and now you just solved my headlight plug issue.
Take a look back in the post to see the red wire I'm talking about.
#20 MiCarl ONLINE
MiCarl
  • 1,746 Thanks
  • 932 posts
Posted June 24, 2017 - 12:35 PM
Yes, plug the tractor power that used to go to the stator leg with the diode (red, I think it was) to the red output from the new regulator/rectifier.
The regulator/rectifier does the same job as the diode did on your old engine, only better.
Edited by MiCarl, June 24, 2017 - 12:36 PM.
  • Skeeter65 said thank you
#21 TomLGT195 OFFLINE
TomLGT195
  • 3,468 Thanks
  • 2,660 posts
Posted June 24, 2017 - 04:13 PM
Welcome to GTTTalk  Where about in NH are you?
#22 Skeeter65 OFFLINE
Skeeter65
  • 4 Thanks
  • 11 posts
Posted June 24, 2017 - 07:09 PM
Thank You! Some really great people on this forum. Posted in another forum and not much help and pretty grumpy too.
I'm in the Lakes Region.
Edited by Skeeter65, June 24, 2017 - 07:12 PM.
  • KennyP and TomLGT195 have said thanks
