Please help, Engine Replacement - see video
21 replies to this topic
#1 Skeeter65 OFFLINE
Skeeter65
  • 4 Thanks
  • 11 posts
Posted June 24, 2017 - 04:15 AM
Hello, I'm swapping out my old Craftsman 15.5 HP Briggs for a new 17.5 hp Briggs and there is a difference in the wiring, please see the video. Thanks!
  • RustyB said thank you
#2 KennyP ONLINE
  • 36,448 Thanks
  • 44,935 posts
Posted June 24, 2017 - 06:57 AM
:wave: Welcome to the forum! I think we can help you out. I have a manual somewhere for a Sears with a 15 HP OHV. Wiring diagram should be in there.
#3 Skeeter65 OFFLINE
Skeeter65
  • 4 Thanks
  • 11 posts
Posted June 24, 2017 - 07:52 AM
Awesome! I think the difference is the old motor had wires coming from the stator and ran into the wiring harnes via a diode....but the new motor utilizes a voltage regulator...so now I'm not sure what (If anything) I need to plug into the old stator wire plug.
#4 KennyP ONLINE
  • 36,448 Thanks
  • 44,935 posts
Posted June 24, 2017 - 07:57 AM
I'll have to go out back and get the model # for the one I have. Do you have the SEARS 917.?????? for yours? Should be under the seat.
#5 jms180 ONLINE
jms180
  • 1,355 Thanks
  • 1,497 posts
Posted June 24, 2017 - 08:12 AM
Welcome to the forum. I have all the confidence that Kenny will be very helpful.
  • TomLGT195 said thank you
#6 Skeeter65 OFFLINE
Skeeter65
  • 4 Thanks
  • 11 posts
Model # 917258534 CRAFTSMAN Lawn, Tractor
Engine Info
Briggs & Stratton
I/C Platinium
15.5 HP OHV
Model# 28N707
Type# 0173-01
Code# 970417ZE
#7 jms180 ONLINE
jms180
  • 1,355 Thanks
  • 1,497 posts
Posted June 24, 2017 - 08:39 AM
I download a manual in the Briggs & Stratton repair section that may be helpful
http://gardentractor...g-diagrhamspdf/
Edited by jms180, June 24, 2017 - 08:42 AM.
  • Oldford and RustyB have said thanks
#8 Skeeter65 OFFLINE
Skeeter65
  • 4 Thanks
  • 11 posts
Posted June 24, 2017 - 09:12 AM
Awesome, I am going to print it out.  Taking a quick look at it that might solve my problem. I appreciate you taking the time to upload that.
#9 Skeeter65 OFFLINE
Skeeter65
  • 4 Thanks
  • 11 posts
Posted June 24, 2017 - 09:32 AM
OK, so looking at the wiring diagram I can see where everything goes...I'm just not sure what to do with the wire that goes to the lights as the new motor does not have a plug for them.  The new motor only has the carb solenoid plug and the single red wire for charging. In the end I really do not care if the lights work, I just want to make sure I am not going to hurt the electrical on the new motor in any way.
#10 Skeeter65 OFFLINE
Skeeter65
  • 4 Thanks
  • 11 posts
Posted June 24, 2017 - 09:41 AM
Please see the attached current wiring diagram and wires on new motor......
Screen Shot 2017 06 24 At 10.21.32 AM
Screen Shot 2017 06 24 At 10.36.16 AM
#11 bhts OFFLINE
bhts
  • 1,460 Thanks
  • 2,156 posts
Posted June 24, 2017 - 09:46 AM
What is the model of the motor you are putting in? Briggs shows a exact replacement for the old one but it is a 15.5hp and not a 17
#12 Tecumseh power OFFLINE
Tecumseh power
  • 1,454 Thanks
  • 1,104 posts
Posted June 24, 2017 - 09:54 AM
Old stator red wire was dc charge to battery , black wire unregulated a.c. volts to lights. If that helps you at all.
Edited by Tecumseh power, June 24, 2017 - 09:54 AM.
  • Skeeter65 said thank you
#13 Skeeter65 OFFLINE
Skeeter65
  • 4 Thanks
  • 11 posts
Posted June 24, 2017 - 09:56 AM
I contacted Sears for a direct replacement, and this is what they sent me... http://www.searspart...mpaign=pd-oc-nb
#14 KennyP ONLINE
  • 36,448 Thanks
  • 44,935 posts
Posted June 24, 2017 - 10:00 AM
I uploaded the owners manual for your tractor. It has the wiring diagram in it.
#15 Skeeter65 OFFLINE
Skeeter65
  • 4 Thanks
  • 11 posts
Posted June 24, 2017 - 10:06 AM
Perfect! Thanks so much for all the help....I now might have enough info to figure this out!  I'll re-post once I have the results.
