Bolens 1050 right side axle seal?
5 replies to this topic
#1 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted June 24, 2017 - 01:01 AM
Guys I am going through a parts list for the 6 speed tranny, I am only seeing a seal listed for the hub lock side. It's leaking on that side but I want to change them both. Surely the right side also has a seal but I can't find it. Does anyone know a part number for the right side. Sorry if this is a dumb question. I just really don't see it on the list or the diagram
#2 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted June 24, 2017 - 01:14 AM
I see no seal on the right side unless I'm looking wrong. Or is it number 73 ? But that stuff looks like it's inside the case .
Edited by Tecumseh power, June 24, 2017 - 01:45 AM.
#3 dtsh OFFLINE
dtsh
  • 248 Thanks
  • 169 posts
Posted June 24, 2017 - 01:47 AM
There should be 2 on the lock side and one on the other. The 3 speed is damn near identical in design and I just finished working on mine.
The outer most left one should be toward the end of the hub, the other, much larger one, will be where the axle section/hub slides into the casing. The right side will be right at the casing, where the hub sections slide on.
Edit: From the parts manual
Left side:
ref#    part#
52      1185295
55      1185643
Right side:
73      1185642
Edit edit: I can't tell my left from my right, as always, double check!
Edited by dtsh, June 24, 2017 - 02:08 AM.
  • Bolens 1000 said thank you
#4 Bolens 1000 ONLINE
  • 15,432 Thanks
  • 18,284 posts
Posted June 24, 2017 - 04:18 AM
Right side is only a single seal on that side 1185642
#5 Tecumseh power OFFLINE
Tecumseh power
  • 1,530 Thanks
  • 1,131 posts
Posted June 24, 2017 - 08:44 AM
Thank you guys
#6 Dave in NY OFFLINE
Dave in NY
  • 86 Thanks
  • 48 posts
Posted June 24, 2017 - 08:54 PM
Just looked in my notebook. Ought to be SKF 11124  available from NAPA.
