Simplicity 7016 Tiller Belt Installation HELP
8 replies to this topic
#1 BTS ONLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,618 posts
Posted June 23, 2017 - 11:47 PM
I got a new belt for the tiller on my simplicity 7016, the old belt worked but it was getting really worn and weathered so I thought I would replace it before it lets me down in a time of need. I removed the old belt, then it rained several inches so I didn't bother putting belt and tiller on till it dried up. Anyway, fast forward a week to so to today, I put the new belt on, all looked good, drove it out to the garden, turned on the tiller and the belt started smoking. I noticed that the belt is rubbing the metal guard bracket thing under the main pulley on the rear of the GT, I believe I have the belt on correct, anyone have a picture or something that shows how the belt goes on, I downloaded several manuals for that model of simplicity and for that tiller, but nothing shows how it goes on.
  • hamman said thank you
#2 KennyP OFFLINE
  • 40,974 Thanks
  • 47,143 posts
Posted June 24, 2017 - 08:05 AM
This pic is from an AC 716 manual. I'm thinking it's the same.
#3 BTS ONLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,618 posts
Posted June 24, 2017 - 09:15 AM
That looks like a older model of tiller, mine doesn't have the idler pulley in the middle
Here are a couple pictures of the tiller that I have
#4 KennyP OFFLINE
  • 40,974 Thanks
  • 47,143 posts
Posted June 24, 2017 - 09:30 AM
Gonna need the model # and I may find a manual for it. Tractor model may show the tiller in the manual.
  • BTS said thank you
#5 SimplyRad OFFLINE
SimplyRad
  • 1,298 Thanks
  • 944 posts
Posted June 24, 2017 - 10:18 AM
It looks to me like you are missing an idler pulley.
http://www.partstree...er-drive-group/
  • drbish and BTS have said thanks
#6 BTS ONLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,618 posts
Posted June 24, 2017 - 10:50 AM
I found this manual for the tiller, but it doesn't show how the belt goes on, I will get the numbers when I have a chance here in a bit.
Thanks for all the help.
(the pictures are of the same tiller I have)
#7 BTS ONLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,618 posts
Posted June 24, 2017 - 10:52 AM
I don't believe this model has the idler pulley, I posted a picture above
Thanks
#8 Oldford OFFLINE
Oldford
  • 1,135 Thanks
  • 786 posts
Posted June 24, 2017 - 11:21 AM
I smoked a new belt on a mower deck once, it was a big craftsman with a lot of pulleys, idlers, etc underneath the tractor.  Turns out I had misrouted the belt over a sharp, sheet metal guide clip that i didn't see the first time, moved the belt under the clip where it was supposed to go and it worked fine after that, good luck
#9 BTS ONLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,618 posts
Posted June 24, 2017 - 12:56 PM
Ok I figured it out!
I guess whoever put the belt on originally got the wrong belt, they went around the tension pulley for the mower deck, I got a belt about 3 inches shorter and it works perfectly.
Sorry for all the trouble and thanks for everyone's help!
