Edited by sacsr, June 23, 2017 - 09:21 PM.
Posted June 23, 2017 - 06:50 PM
Posted June 23, 2017 - 08:10 PM
Neat little horse you got there Scott.
I think you need 3 batteries, 36volts to run the drive motor.
Is the 100amp fuse good?
Is the safety switch good?
Is the key switch good?
Is the Traction solenoid good?
There's not much else besides wires and connections.
Posted June 23, 2017 - 08:26 PM
What he said! You should be able to drive it without engaging the blade motors. If you are worried about the blades engaging, then disconnect the mower switch. Rick
Posted June 23, 2017 - 09:20 PM
Edited by sacsr, June 23, 2017 - 09:23 PM.
Posted June 23, 2017 - 09:33 PM
If you replaced the Traction Solenoid with a 12volt solenoid and wired it up as in the drawing it would work. Run on 12volts.
12volts isn't enough to turn on a 36volt solenoid. How does he turn on and off the motor?
Posted June 23, 2017 - 10:28 PM
Posted June 24, 2017 - 11:48 AM
Nice score. I have built and wired motorcycles from scratch, rewired garden tractors, boats, even built 48v electric bicycles from scratch. I even have a college degree although it's just for readin and writin.' But i am just not smart enough to figure out these old electric tractors. It amazes me how smart some of you guys are.
Posted June 24, 2017 - 12:11 PM
Posted June 24, 2017 - 12:56 PM
Scott, where's the gas tank?
