ark 700 loader,
pump specs
11 replies to this topic
#1 sodbuster10231 OFFLINE
sodbuster10231
  • 18 Thanks
  • 37 posts
Posted June 23, 2017 - 04:09 PM
installing ark 700 loader on my ht23.need specific pump number to replace Cessna pump.I am driving it off front pto shaft. need gpm,also need pics of front mount,and number of lovejoy coupling.thanks
  • Oldford said thank you
#2 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,584 Thanks
  • 968 posts
Posted June 23, 2017 - 08:08 PM
http://gardentractor...pump-questions/
Some info here. I'll try to dig a pump info out and the lovejoy size
  • blackjackjakexxix, Oldford and sodbuster10231 have said thanks
#3 Oldford OFFLINE
Oldford
  • 1,134 Thanks
  • 786 posts
Posted June 24, 2017 - 11:34 AM
Sounds like a nice project, post up some pics...
#4 sodbuster10231 OFFLINE
sodbuster10231
  • 18 Thanks
  • 37 posts
Posted June 24, 2017 - 03:39 PM
I welded loader to tractor..I dont ever plan on using it for anything else. I will get some pics. I don't have all the braces made yet. trust me it is heavy duty! I have some 50 lb wheel weights,think that's to much? I plan on mounting pump on the front.no one here can cut a key way.so need more info on coupler.does anyone know gpm? sealed unit with reserve in upright.thanks again!
Edited by sodbuster10231, June 24, 2017 - 03:41 PM.
  • Mark 149 J. said thank you
#5 sodbuster10231 OFFLINE
sodbuster10231
  • 18 Thanks
  • 37 posts
Posted June 28, 2017 - 08:33 PM
finally progress on the loader. brackets welded up. still need to finish front pump mount,
#6 nsengineer OFFLINE
nsengineer
  • 101 Thanks
  • 63 posts
Posted June 28, 2017 - 09:59 PM
I don't think 50 lb weights are too much at all.  If it were mine Id load the wheels also.  If I ever get my HT20D running i would love to have a loader for it.  Good work.
  • sodbuster10231 said thank you
#7 sodbuster10231 OFFLINE
sodbuster10231
  • 18 Thanks
  • 37 posts
Posted June 29, 2017 - 11:11 AM
be patient! keep your eyes and ears open! picked this loader up by a chance encounter. I have cut loaders down before,seems like loaders for compact tractors are common.it takes work to cut one down,  to fit a garden tractor.
#8 Oldford OFFLINE
Oldford
  • 1,134 Thanks
  • 786 posts
Posted June 29, 2017 - 12:20 PM
Wheel weights are good.  for a loader i like a weight box, looks like you have the welding skills to make your own if can't find one
#9 sodbuster10231 OFFLINE
sodbuster10231
  • 18 Thanks
  • 37 posts
Posted June 29, 2017 - 05:52 PM
anytime,I can weld one up for you.
#10 sodbuster10231 OFFLINE
sodbuster10231
  • 18 Thanks
  • 37 posts
Posted August 04, 2017 - 06:16 PM
I need to thank BLACKJACKJAKExxix, CEVANS,STIEMMY,WILBERJ,WRENCHENONIT,STIEMMY for all the information,help,and parts!! thanks again,hope I did not forget anyone.
  • LPBolens, blackjackjakexxix and kjmweld have said thanks
#11 kjmweld ONLINE
kjmweld
  • 424 Thanks
  • 308 posts
Posted August 04, 2017 - 06:30 PM
Turned out nice, looks good on there. Now find me one, lol
#12 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,358 Thanks
  • 1,333 posts
Posted August 04, 2017 - 11:11 PM
I had duals on my Cub 149 w/fel and I have rim guard in all 4 tires.  Each tire weights about 90lbs.  I don't think 50lbs on each side will  be enough for heavier loads.  I would recommend a liquid ballast in the tires as well.  IMO
