Governor Issue on 8hp briggs L Head
7 replies to this topic
#1 bbuckler OFFLINE
bbuckler
  • 3,321 Thanks
  • 2,980 posts
Posted June 22, 2017 - 09:49 AM
Set the governor to factory spec but still it doesn't want to close the throttle so I checked the governor gear it isn't stripped but the spring loaded part seems to be sticking a little. The oil was turning to slime so I wonder if I should just try a oil change with a additive or replace the governor gear.
Edited by bbuckler, June 22, 2017 - 10:18 AM.
  • chieffan said thank you
#2 secondtry OFFLINE
secondtry
  • 1,686 Thanks
  • 1,286 posts
Posted June 22, 2017 - 10:09 AM
Not exactly sure what you are saying. If the gear is striped it would seem obvious to change it. and also do a thorough cleaning to to make sure all the debris is not left to plug oil passages and foul the works. Don
  • Alc and chieffan have said thanks
#3 bbuckler OFFLINE
bbuckler
  • 3,321 Thanks
  • 2,980 posts
Posted June 22, 2017 - 10:18 AM
 I mean't isn't
#4 secondtry OFFLINE
secondtry
  • 1,686 Thanks
  • 1,286 posts
Posted June 22, 2017 - 10:38 AM
 Makes much more sense now, by all means if the oil is suspect change it. I am not a fan of additives, if I think the oil is not up to the job I look for better oil. Don
#5 bbuckler OFFLINE
bbuckler
  • 3,321 Thanks
  • 2,980 posts
Posted June 22, 2017 - 10:58 AM
I usually use something like seafoam in the oil to flush out the old out.
#6 chieffan OFFLINE
  • 9,598 Thanks
  • 6,424 posts
Posted June 22, 2017 - 12:47 PM
Diesel fuel makes as good a flush as any.  If it don't want to idle down check your linkage, something may not be hooked up right.
  • secondtry said thank you
#7 bbuckler OFFLINE
bbuckler
  • 3,321 Thanks
  • 2,980 posts
Posted June 22, 2017 - 12:58 PM
I'm starting to think it the spring it pulling it down which is open.
#8 bbuckler OFFLINE
bbuckler
  • 3,321 Thanks
  • 2,980 posts
Posted June 22, 2017 - 01:23 PM
