Stop Me, going wrong way! Bolens H16XL
27 replies to this topic
#16 glgrumpy ONLINE
  • 8,498 Thanks
  • 7,856 posts
Posted June 22, 2017 - 05:04 PM
Pix. Dash nice, seat pan nice, orig rib tires and caps?, engine oily and dirty, exhaust needs work.pulley IS off. She had and new belt. Hole in pulley wallow ed out. Not sure on shaft yet. Anyone have? New belt with it.
  • KennyP, Sawdust, Oldford and 1 other said thanks
#17 glgrumpy ONLINE
  • 8,498 Thanks
  • 7,856 posts
Posted June 22, 2017 - 05:05 PM
Gonna like this one I think. Took video, will work on link.
  • KennyP and Sawdust have said thanks
#18 Sawdust ONLINE
Sawdust
  • 5,449 Thanks
  • 3,295 posts
Posted June 22, 2017 - 05:58 PM
I think you did well on this one GL. Looking forward to the video.
#19 Oldford OFFLINE
Oldford
  • 1,134 Thanks
  • 786 posts
Posted June 23, 2017 - 03:35 AM
They are nice tractors.  Yours looks in good shape.  This should be the manual http://gardentractor...e/1504-1668pdf/
This looks like the manual for the rear discharge deck http://gardentractor...-18335-42inpdf/
That double deck pulley is expensive new.  tho one just sold on ebay pretty cheap.  maybe a machine shop to fix yours...?
#20 TAHOE OFFLINE
TAHOE
  • 7,748 Thanks
  • 5,583 posts
Posted June 23, 2017 - 11:11 AM
Looks like the push rods tubes are leaky on this motor too  :D
  • Sawdust said thank you
#21 glgrumpy ONLINE
  • 8,498 Thanks
  • 7,856 posts
Posted June 23, 2017 - 08:40 PM
OK, pulled deck off to take a look at front spindle. First, it looks like it is orig round size, not all gored. Did find what must be remains of a key? The whole spindle kind of moves up /down a bit when pulled from blade side. Now, when messing with, I pushed it back and the bearing pulled out some with movement. Should this shaft if clean be able to just be floating in that housing till blade is on?? or Pulley? Look at couple pix and see if you can see anything wrong in bottom veiw, heh!
Edited by glgrumpy, June 23, 2017 - 08:44 PM.
#22 Bolens 1000 ONLINE
  • 14,809 Thanks
  • 18,054 posts
Posted June 24, 2017 - 05:17 AM
someone got the center blade on wrong !
  • MH81, EricFromPa, Sawdust and 1 other said thanks
#23 glgrumpy ONLINE
  • 8,498 Thanks
  • 7,856 posts
Posted June 25, 2017 - 07:55 PM
Power wash today. Here's B4 pix. Thought engine was Gold, but think silver orig, just dirty now. Look at black under hood and sides. Think mostly carbon from no muffler a long time. Had one wired on it, all loosey.
#24 glgrumpy ONLINE
  • 8,498 Thanks
  • 7,856 posts
Posted June 25, 2017 - 08:01 PM
More after pix. Much better, till I climbed under, heh! Had jacked up, still lots missed. That black didn't clean good, even with soap and sponge. Tried some bleach and better, not best.
#25 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,313 Thanks
  • 1,733 posts
Posted June 25, 2017 - 08:34 PM
Get you a clay bar on that hood. If the paint is there, it'll shine it up real good.
Eric
Edited by dropped82, June 25, 2017 - 08:34 PM.
#26 kjmweld ONLINE
kjmweld
  • 384 Thanks
  • 296 posts
Posted June 25, 2017 - 10:20 PM
Good lordy, that looks like it was driven thru a swamp... much cleaner now tho. The plus side to all the grunge is it's a great paint preserver. Now you can see better what ya got. Good luck with things GL.
  • BolensHorse72 said thank you
#27 glgrumpy ONLINE
  • 8,498 Thanks
  • 7,856 posts
Posted July 04, 2017 - 12:30 PM
Video link?https://youtu.be/M-KKRvPvVZw
Edited by glgrumpy, July 04, 2017 - 12:37 PM.
#28 kjmweld ONLINE
kjmweld
  • 384 Thanks
  • 296 posts
Posted July 04, 2017 - 01:41 PM
That cleaned up nice. Ended up being a good buy it looks like.
