Scored a GT 3000 Today!
77 replies to this topic
#46 TomLGT195 OFFLINE
TomLGT195
  • 4,095 Thanks
  • 2,926 posts
Posted July 18, 2017 - 05:21 PM
Good for parts then! I know you'll be able to make one good one out of these.
#47 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 18, 2017 - 05:23 PM
I removed the flywheel and stator since I know they work. Put the old flywheel back on so I can start a drive this thing. HGere's what it looks like with the hood back on.
The Right front wheel is not correct and rubs badly inside, but I can at least move it under it's own power.
  • Sawdust said thank you
#48 Sawdust OFFLINE
Sawdust
  • 6,217 Thanks
  • 3,581 posts
Posted July 19, 2017 - 08:29 AM
That last pic looks like a demolition tractor from a county fair. Did you say you were going to make one of these your mower. I've been following threads that are doing what you are, salvaging some of these newer mowers. A lot of fun following.
#49 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 19, 2017 - 10:22 AM
I'm going to try. The Poulan had a 54" deck and the spindles are good on it. The Sears has a 48" deck, not sure about it yet. Gotta get the flywheel on it to see if it runs. The Sears is the better looking of the two, for sure.
#50 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 19, 2017 - 02:29 PM
I swapped the tractors around this morning using the FF/20 and boom pole. Had to add two of the suitcase weights to the front. Had to get the blow gun out and clean things up a bit. Made sure fins were clean along with the oil cooler. Put the stator and flywheel on, set the gaps with my 'official' gauge.
Closed it up.
Hooked a battery up and a temp fuel tank. It fired right up! Sounds real good, but needs a muffler. Went to check tranny and deck. If I let the clutch out it tries to die. Same with the PTO switch, so have something in the safeties messed up. Time to study the wiring schematic.
  • 29 Chev said thank you
#51 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 19, 2017 - 05:52 PM
Looks like the solenoid is the issue. Tried to wire around, but no go.
Edit: I posted the wrong schematic pic yesterday. Got the right one now.
Edited by KennyP, July 20, 2017 - 06:39 AM.
Wrong Schematic
#52 TomLGT195 OFFLINE
TomLGT195
  • 4,095 Thanks
  • 2,926 posts
Posted July 20, 2017 - 03:36 AM
Can you steal the one from the Poulan?
Edited by TomLGT195, July 20, 2017 - 03:37 AM.
#53 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 20, 2017 - 04:55 AM
I looked, doesn't have the relay. Don't think I have one on anything else.
  • TomLGT195 said thank you
#54 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 20, 2017 - 10:18 AM
I went and got a new solenoid. Plugged it in and everything works as it should! May not get too much more done on it today, my son is passing through on his way to Florida!
#55 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 20, 2017 - 05:29 PM
After my son left out, I put some Seafoam and gas in the tank of the GT3000. Let that set for an hour or so and drained it out. It looked about the same as what went in, so I hooked the tank back to the fuel system and put some gas in it. Stuck a battery in and got it out. Drove around some first, then put the mower to work.Does a good job mowing and is easy to steer around things. So I need to lube it all up and put more time on it. Both back tires and the left front have leaks, need to fix those, but I can put it to work. Here's what I mowed with it.
I am gluing part of the front grille back together with the E6000. It takes up to 72 hrs. to reach full strength, so I may not have the hood back on for a bit. Probably need to sharpen the blades too. But I'm happy with my 'cheap' mower.
  • TomLGT195 and Mark 149 J. have said thanks
#56 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 21, 2017 - 01:44 PM
I have messed with the Sears some and the hydro doesn't like to back up. A snail is faster! :wallbanging: The Poulan works better, less hours. Here a list of the Poulan cons.
1. Has 6" wheels on front instead of 8".
2. PTO clutch froze up.
3. Needs flywheel and stator.
4. Seat came unglued from the pan and is not good enough to use.
5. Hood is all bent up and no grille section.
So I think I will swap this Hydro into the Sears. If I find a flywheel and stator cheap, I may put this engine into the JD 265 I have out back with a blown 17 HP Kawasaki. That should make it a good mower!
  • TomLGT195 and toppop52 have said thanks
#57 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,640 Thanks
  • 4,638 posts
Posted July 21, 2017 - 01:57 PM
Hay Kenny. I have another decent Seat if you want it.
#58 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 21, 2017 - 02:00 PM
Send me a pic in a PM. We'll talk about it!
#59 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted July 21, 2017 - 02:21 PM
Well, just talked to a REP of hydro-gear and these two hydros are not interchangeable. That sucks. They say most are brand specific!
So I have a great running mower that won't back up a foot in three hours!
#60 TomLGT195 OFFLINE
TomLGT195
  • 4,095 Thanks
  • 2,926 posts
Posted July 21, 2017 - 05:15 PM
So just go in circles!      :smilewink:  :smilewink:
I'll bet if you look at it more closely you might be able to make it work. I would think the only real difference would be mounting tabs?
Can you take a pic of both tractors from the back to see how different they are??
Edited by TomLGT195, July 21, 2017 - 05:16 PM.
