Scored a GT 3000 Today!
75 replies to this topic
#1 KennyP ONLINE
  • 38,394 Thanks
  • 45,939 posts
Posted June 21, 2017 - 05:04 PM
I took my LT4000 over to my daughters for them to use. I remembered seeing a Craftsman tractor setting with tall grass around it close by, so I drove by there! I left a note and went around the block to get back out. They were home by then, so I  stopped back in.
Anyways, made the deal and hauled it home! Took a bit to get it running, but here it is! It's a 25 HP Kohler Pro series engine!
Hour meter shows 658 hrs. Has 24 X12- 12's on the back!
  • EricFromPa, WrenchinOnIt, Traill95 and 10 others have said thanks
#2 jms180 ONLINE
jms180
  • 1,517 Thanks
  • 1,567 posts
Posted June 21, 2017 - 05:09 PM
Nice find Kenny those Kohler pro twins are great engines. The courage engine not so much
#3 jms180 ONLINE
jms180
  • 1,517 Thanks
  • 1,567 posts
Posted June 21, 2017 - 05:15 PM
Also doesnt take you long to get one running.
#4 glgrumpy OFFLINE
  • 8,612 Thanks
  • 7,920 posts
Posted June 21, 2017 - 05:21 PM
Nice! That's just what I need a neglected Sears to get engine for my Husqvarna. Probly about same tractor and might drop in easier??  Commands no good?  What is diff?  I see they have Cast Sleeves, is that issue?  Pros have cast jugs then?  Even one with a bigger Briggs would still work for me, just has to be cheap, like Me to get it. Looking for that one with broken rear axle I hear so many have!
#5 KennyP ONLINE
  • 38,394 Thanks
  • 45,939 posts
Posted June 21, 2017 - 05:40 PM
This one is model # 917.275223, Gary. Might give you an idea of what to look for!
#6 bbuckler ONLINE
bbuckler
  • 3,475 Thanks
  • 3,068 posts
Posted June 21, 2017 - 09:40 PM
If you was close I could made you a deal on a Kohler Pro 25 hp. I'm parting out a scag ztr.
#7 MH81 OFFLINE
Posted June 21, 2017 - 09:59 PM
Great score Kenny. They're good machines in today's world
What year is that?
#8 KennyP ONLINE
  • 38,394 Thanks
  • 45,939 posts
Posted June 22, 2017 - 04:59 AM
What year is that?
Not sure yet. I'll have to find the #'s on the Kohler. I need to take the flywheel shroud off and clean out wasp nests. I found an OM for it through Sears parts.
#9 MH81 OFFLINE
Posted June 22, 2017 - 06:35 AM
It may have a convoluted belt routing, but at least it doesn't have that POS splined input pulley that my 6000 has.
The tranny is a hydrogear. Nice. Means it has a filter (internal) and is well built IMHO.
BTW, if the tranny has a little plate on the bottom with 2 bolts holding it, that's the precharge pump cover and they will leak. Be a good idea to check fluids before moving.
One of ours leaked & I tried several things to stop it... no joy.
Depending on the style, there is an upgraded (thicker) cover and rotor that can go on it. Took some Google-fu, but IIRC, it was the cover and rotor from a ZTR that would deal with the issue.
The model of your hydro is 311-3500 and isn't listed on HG's site, but if you call them, they'll tell you which service manual to DL.
  • KennyP, TomLGT195, Sawdust and 1 other said thanks
#10 KennyP ONLINE
  • 38,394 Thanks
  • 45,939 posts
Posted June 22, 2017 - 06:44 AM
It may turn into a keeper! I'll clean under that shroud today and put a bigger battery in it. It has a good 275 CCA, but the manual says a 280CCA minimum. That could make the starter work harder. I tried the PTO switch yesterday, but it would just kill the engine. Blades didn't try to turn. May be I had the brake locked down. I have a jumper in the seat switch just to get it running. I'm just happy it started. I have a temp gas tank on it as I have no idea what may be in the seat tank!
#11 KennyP ONLINE
  • 38,394 Thanks
  • 45,939 posts
Posted June 22, 2017 - 07:20 AM
Here's the push mower I got with it. I didn't even look to see what brand it was until this morning,
  • Trav1s, WrenchinOnIt, Sawdust and 1 other said thanks
#12 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,008 Thanks
  • 4,414 posts
Posted June 22, 2017 - 07:31 AM
Nice score Kenny!
#13 Rock farmer ONLINE
Rock farmer
  • 1,198 Thanks
  • 1,233 posts
Posted June 22, 2017 - 07:46 AM
A Jo Deere.
That's John's younger brother.
Much less well known!
Joe
  • MH81, KennyP, Trav1s and 2 others have said thanks
#14 KennyP ONLINE
  • 38,394 Thanks
  • 45,939 posts
Posted June 22, 2017 - 07:57 AM
Well, I gotta change the title of this thread as it is a GT3000. I didn't look real close at the decal with the hood on the ground, looked like a 6 from there. I have some more pics of it and copied all the pertinent #'s down.
Tractor Model : 917.275223
Serial              : 030601A001146
Engine Model  : CV742S
Spec                : 69581
Serial               : 3105212241
I think that oil cooler is cool. Has grease zerks on the deck spindles.
  • Mark 149 J. said thank you
#15 MH81 OFFLINE
Posted June 22, 2017 - 07:58 AM
With the "Jo" spelling, it's probably younger sister
  • KennyP, Trav1s and Rock farmer have said thanks
