Wiring Diagrams. 1455 electrical system
1455 wisconsin 14hp electrical diagrams
11 replies to this topic
#1 Harleyguy70 OFFLINE
Harleyguy70
  • 17 Thanks
  • 13 posts
Posted June 21, 2017 - 01:49 PM
I'm looking for a wiring diagram for My Bolens 1455.  Any help appreciated.
#2 Merle013 OFFLINE
Merle013
    If I can't do it slow then it's not going to get done.
  • 258 Thanks
  • 180 posts
Posted June 21, 2017 - 03:20 PM
I downloaded a copy of the 1455 parts manual from our manuals section. Check it out.
  • Harleyguy70 said thank you
#3 kjmweld ONLINE
kjmweld
  • 384 Thanks
  • 296 posts
Posted June 21, 2017 - 03:29 PM
Hopefully this will help out.
  • Rock farmer, Doug E. and Harleyguy70 have said thanks
#4 wilberj ONLINE
wilberj
  • 4,940 Thanks
  • 5,569 posts
Posted June 21, 2017 - 05:55 PM
Is your 1455 a 198-01 or 198-02?  The 01 had points well the 02 had solid state just FYI.
  • Bolens 1000 and Harleyguy70 have said thanks
#5 Harleyguy70 OFFLINE
Harleyguy70
  • 17 Thanks
  • 13 posts
Posted June 22, 2017 - 01:16 PM
Got it fellas...........thx all....
#6 Harleyguy70 OFFLINE
Harleyguy70
  • 17 Thanks
  • 13 posts
Posted June 24, 2017 - 01:18 PM
Is there an aftermarket ignition coil for my Wisconsin S14D w/breakerless ign?
#7 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted June 24, 2017 - 08:19 PM
Yes, there are cheap alternative coils that can be had from any autoparts store, but Id throw caution to the wind if you are having spark issues??
#8 Harleyguy70 OFFLINE
Harleyguy70
  • 17 Thanks
  • 13 posts
Posted June 29, 2017 - 03:11 PM
Found a coil but wiring diagram isn't clear on hook up.  Which wires go to which side of coil?  Diagram says ign wire to + side of coil.  Doesn't show which wire goes to negative side.
#9 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted June 29, 2017 - 03:34 PM
If its the points version, the lead from the points goes to the negative terminal on the coil.
#10 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted June 29, 2017 - 03:35 PM
If it is the electronic version, the ground goes to the key, or an add on kill switch to ground, and the hot (+) goes to the module.
Edited by stiemmy, June 29, 2017 - 03:44 PM.
  • kjmweld and Harleyguy70 have said thanks
#11 Harleyguy70 OFFLINE
Harleyguy70
  • 17 Thanks
  • 13 posts
Posted June 30, 2017 - 07:46 AM
I did the kill switch route Stiemmy.  Purrs like a kitten.  thx again.   Dick
  • stiemmy said thank you
#12 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted June 30, 2017 - 01:32 PM
You betcha, anytime!!!
Glad you got er runnin again.
