snowblower question
3 replies to this topic
#1 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted June 18, 2011 - 08:41 PM
Can anyone tell me if I can use a snowblower made for the 300 series tractors on a 212 thank you
#2 jdslednut OFFLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted June 18, 2011 - 11:05 PM
It will not. I believe the 300 series should take a model 47 or 49 and the 212 a 37 or 37A (or a 36 with an adapter bracket).
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted June 19, 2011 - 06:04 AM
The main reason for the lack of compatibility is that the 300 series is shaft driven, with the crankshaft running front to back and the PTO on the front of the tractor, while the 200series has the PTO on the side. When you first look at the 2 tractors they look similar in size, weight and HP but there are major differences in the drivetrain and hydraulics.
#4 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted June 19, 2011 - 03:16 PM
ok thank you
