Tube frame snow plow mount bracket
5 replies to this topic
#1 Jooohan87 OFFLINE
Jooohan87
  • 11 Thanks
  • 22 posts
Posted June 20, 2017 - 07:48 PM
Hello
Trying to figure out where to put the lift assembly on the plow bracket for my 800, can anyone take some measurementa for me? As always its hard to find attachments over here.
Need from mounting hole in front end of the tractor to where the plate is welded on bracket.
And how high the plate is and where to put the pin for lift rod.
If possible how much bended out the plate is
Thanks
#2 glgrumpy OFFLINE
  • 8,612 Thanks
  • 7,920 posts
Posted June 21, 2017 - 06:11 AM
?? Those spaces fit over cast tabs on axle with big pins or bolts. That lift looks fine. There is a flat strap link from it to lift handle. Is couple odd bends and a slot in that.
#3 Jooohan87 OFFLINE
Jooohan87
  • 11 Thanks
  • 22 posts
Posted June 21, 2017 - 11:00 AM
Its not mine on the picture, I need measurement from one so I can fabricate it.
Thanks
#4 Jooohan87 OFFLINE
Jooohan87
  • 11 Thanks
  • 22 posts
Posted June 23, 2017 - 03:13 PM
Anyone?
#5 Jooohan87 OFFLINE
Jooohan87
  • 11 Thanks
  • 22 posts
Posted June 24, 2017 - 11:24 PM
Did a quick "drawing" on the phone, not the easiest. Hehe.
Just need theese measurement.
Thanks
#6 dtsh OFFLINE
dtsh
  • 234 Thanks
  • 159 posts
Posted June 30, 2017 - 07:16 PM
My plow is in storage, so it took me a while to get to it. Here are the measurements I have. Where I could, I measured from roughly the center of holes/pins.
A = 21.5"
B= 3.5"
Height = 5.5"
Also, the lift arm at B has a "Z" bend in it which brings the top of the arm 2.5" farther out than the frame.
Edited by dtsh, June 30, 2017 - 07:17 PM.
