What are the odds this will work?
17 replies to this topic
#1 Reed Breneman OFFLINE
Reed Breneman
  • 1,886 Thanks
  • 650 posts
Posted June 20, 2017 - 01:37 PM
I am working on a Briggs 3.5 hp motor on a tiller,no spark,Well the reason is the flywheel key way has a big ole chunk out of it so it looses time by a hair and wont fire,Basically one whole side of the keyway is broke out and gone,There is just enough left at each end of the crank shaft I got it to stay running for a minute or two,Question is what are the odds I can weld on the crank shaft ,build it up a little then grind it out to refit a key,I am not worried about my skills as this is right up my alley ,I just wonder if it can be done in the motor with out ruining the seals??I will get some pics of it soon
#2 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,856 Thanks
  • 4,349 posts
Posted June 20, 2017 - 03:05 PM
Sounds like someone put a steel key in instead of the aluminum one. I had one similar a long time ago. Tossed the whole engine, and eventually the tiller part. Pretty sure you will fry the seal.
  • Sawdust and Reed Breneman have said thanks
#3 daniel_b OFFLINE
daniel_b
  • 96 Thanks
  • 89 posts
Posted June 20, 2017 - 03:26 PM
maybe with a little help from my frien' JB   :D
  • Reed Breneman said thank you
#4 chieffan ONLINE
  • 9,579 Thanks
  • 6,413 posts
Posted June 20, 2017 - 03:34 PM
If you do try welding it, put a couple clamps between the seal and weld area to slow the transfer of heat.  Then weld a bit at a time allowing it to cool some between welds times.  Is it a half moon key or straight?  Might try JB and put it together before the JB sets up - and hope you don't have to take it apart again.
#5 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 12,979 Thanks
  • 9,624 posts
Posted June 20, 2017 - 03:37 PM
Maybe fabricate a temporary key from nylon/plastic which will not adher.
#6 Bill 76 ONLINE
Bill 76
  • 1,892 Thanks
  • 1,178 posts
Posted June 20, 2017 - 03:45 PM
Probably doable if you have a tig welder , just burn in a little at a time. Heat sink paste works good but would cost more than the engine is worth .
Try grinding it to fit a bigger key , got nothing to lose the crank is already on its last leg.
#7 Reed Breneman OFFLINE
Reed Breneman
  • 1,886 Thanks
  • 650 posts
Posted June 20, 2017 - 03:58 PM
I got it welded up pretty fair ,dont want to heat it anymore or the seal will be shot ,so far so good,trying to reshape everything is the fun part ,Pics coming
#8 BigFlash OFFLINE
BigFlash
  • 244 Thanks
  • 132 posts
Posted June 20, 2017 - 05:03 PM
Get the key way as good as you can and then put the flywheel on with either red loctite or bearing mount. It will help considerably with keeping the flywheel on the shaft in the right spot, and some heat from a propane torch and a puller will have it back off with relative ease incase of future repairs.
#9 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted June 20, 2017 - 07:18 PM
I vote for JB Weld.  I had a wood chipper with a damaged output shaft.  Ran for years with JB Weld.  If it will take that abuse, a tiller should be a breeze.  I made a key & a sleeve, installed the key, plastered on the JB & slide the sleeve over the shaft.  I split the sleeve so it would slide on past the key & hose clamped it tight.  Once it curred, I filed it to fit the chipper flywheel.
Edited by New.Canadian.DB.Owner, June 20, 2017 - 07:18 PM.
  • Alc, Cvans, LilysDad and 1 other said thanks
#10 Reed Breneman OFFLINE
Reed Breneman
  • 1,886 Thanks
  • 650 posts
Posted June 20, 2017 - 08:43 PM
That was a big chunk missing JB weld has saved my bacon before also
  • Cvans said thank you
#11 Reed Breneman OFFLINE
Reed Breneman
  • 1,886 Thanks
  • 650 posts
Posted June 20, 2017 - 08:48 PM
I hadnt thought about loctite ,,,That will be next after i get the flywheel on straight.Right now it wobbles ,I need to shave some of my weld off,Its real close though!Its a customer machine and I told him it may not work out but i would try,He said not to spend more then $100 parts and labor on it,,,Well the labor end will be more but he is a good guy and will bring me more stuff so I will eat a little labor! :thumbs:
#12 Reed Breneman OFFLINE
Reed Breneman
  • 1,886 Thanks
  • 650 posts
Posted June 20, 2017 - 08:50 PM
It is a straight key
#13 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted June 20, 2017 - 11:21 PM
Myself, I would weld it up.
Take a wet rag, and wrap it around the shaft in front of the seal, weld it, and shape it. It will be just fine
#14 Cvans ONLINE
  • 6,464 Thanks
  • 6,056 posts
Posted June 20, 2017 - 11:38 PM
Dremel and a cut off wheel will dress up the key way. I have had excellent luck using these.
#15 secondtry OFFLINE
secondtry
  • 1,681 Thanks
  • 1,284 posts
Posted June 21, 2017 - 12:06 AM
   Welding on one side of a shaft, or any thing else will cause distortion. the chances a machined shaft will still be straight after being welded are very close to 0. I have used red locktight on key way repairs before with good luck but never on a fly wheel. Don
  • Cvans and Reed Breneman have said thanks
