Engine swap on 71 Custom 10xl?
4 replies to this topic
#1 Firefighter912 OFFLINE
Firefighter912
  • 12 Thanks
  • 128 posts
Posted June 19, 2017 - 11:20 AM
Is it possible to use another higher HP horizontal shaft engine on these little garden tractors?
If so, what has most people used?
#2 pharmer ONLINE
pharmer
  • 848 Thanks
  • 762 posts
Posted June 19, 2017 - 11:32 AM
I've seen a 460ci put into a Pinto. Anything is possible.
#3 Merle013 OFFLINE
Merle013
    If I can't do it slow then it's not going to get done.
  • 257 Thanks
  • 180 posts
Posted June 19, 2017 - 12:16 PM
Pharmer is correct. Anything is possible. This is a project that I am working on. JD 56 re-powered with an OHV 14 HP Briggs. The fit was tight but I think it will be worth the work. One thing to check is your blade tip speed (BTS). The formula I found is; BTS = Engine RPM X blade length X 0.262. The gov. mandated (ANSI) speed is 19,000 FPM or 200 MPH. Make sure that the pulley and drive system will handle the extra power. Mine is chain drive with a 3 speed tranny.
#4 CRFarnsworth ONLINE
CRFarnsworth
  • 4,319 Thanks
  • 1,991 posts
Posted June 19, 2017 - 05:13 PM
Yep, you can do what you want.
Adapting a different power plant usually requires different belts, pulleys, etc.
I have two xl10s.  Each is waiting to be repowered.  One will receive a 10hp Kohler, the other is getting a different but newer NOS Tecumseh.   Hopefully, once positioned they will only require a different length belt. And some new wiring/ignition switch.
Go for it.    Rick
  • Countryboo said thank you
#5 JiminRI OFFLINE
JiminRI
  • 84 Thanks
  • 80 posts
Posted June 19, 2017 - 10:10 PM
The attached Tecumseh manual has engine specs including physical dimensions for 2 to 18 HP engines.
Maybe you can start there?
Good luck,
Edited by JiminRI, June 19, 2017 - 10:11 PM.
  • Merle013 said thank you
