Snapper Dozer Blade Cross Fit?
2 replies to this topic
#1 Nevrdun OFFLINE
Nevrdun
  • 14 Thanks
  • 17 posts
Posted June 18, 2017 - 09:47 PM
Does anyone know if a dozer blade from a Snapper 1200 will fit a Massey 1450? s-l5002.jpg s-l500.jpg
#2 glgrumpy OFFLINE
  • 9087 Thanks
  • 8191 posts
Posted June 19, 2017 - 07:35 AM
Snappers and Masseys are same tractor for many of models and years.  This sure looks like same design as Massey I had in past. Some have a bent up end or add on at rear to reach up to the rear hitch hole. If this one is not level, could maybe add that. Also, looks like the turn lever needs some work, shouldn't be leaning way out like that! Has to clear tractor, BUT, that is way too far out.  There are also some metal guide parts that mount to front of the tractor to keep the main beam from moving right or left when used. You can make those up if you don't have. Best thing is to get the orig equipment manual for the blades and see how they mount and move them and adapt to yours.
  • James Bosma said thank you
#3 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted June 19, 2017 - 07:16 PM
Looks if that is off a 1600or 1650 snapper. This will mount right up to your Massey 1200.should be a 48" blade. I think the original should be a 40 " for a 1200,but with some weight,you should be good to go.
