Allis 720
127 replies to this topic
#61 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted July 16, 2011 - 11:43 AM
The CCKA runs great! Not a hint of smoke, and 30psi oil pressure at idle. Just a few seconds of video.
#62 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted July 16, 2011 - 11:44 AM
I just noticed....it appears it has one plug wire off! And it sounded great! Wait till it has both cylinders hitting! Had to do the video at a dead run....another busy day.
#63 mjodrey OFFLINE
Posted July 16, 2011 - 12:06 PM
It sure does look like it has a plug wire off. Thanks for sharing that video.
#64 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted July 16, 2011 - 01:14 PM
OK, here's a video with it hitting on both cylinders. Lots smoother! LOL I am varying the throttle.
#65 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted July 16, 2011 - 01:17 PM
With a little bit of luck, the tractor might get a test drive tomorrow! :thumbs:
#66 KennyP ONLINE
  • 38,284 Thanks
  • 45,886 posts
Posted July 16, 2011 - 02:58 PM
Glad you have it going. Good luck with it.
#67 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted July 16, 2011 - 10:34 PM
Drive it on up here and we'll hook it up to the JD2020 :)
#68 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted July 16, 2011 - 10:38 PM
The 2020??? So the 430 is hiding scared huh! :bigrofl:
#69 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted July 16, 2011 - 10:41 PM
Actually, you'd be quite safe with any tractor. I forgot I don't have the drive belts yet, & likely have to get them at NAPA & they are closed tomorrow. BUT, I do have a length of the link type 1/2" belting, so I can make any length needed for just one belt, to at least get it to pull me around if I get that far tomorrow. Supposed to have twin 1/" x 24" belts.
#70 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted July 17, 2011 - 11:53 AM
The linked belt I had made 2 complete drive belts, so it should pull fine till I can get new normal belts. Engine mounted, trans plate removed & found oil to be fine. Just a little wiring work & she'll be about ready to fire up. Not figured out the new exhaust system yet, so may remove the hood until I can build an exhaust.
#71 justwalt OFFLINE
justwalt
  • 4 Thanks
  • 112 posts
Posted July 17, 2011 - 01:15 PM
Just read through most of this thread, what a cool looking machine.
#72 MAV OFFLINE
MAV
  • 110 Thanks
  • 215 posts
Posted July 17, 2011 - 01:21 PM
Hey Daniel, My uncle bought one of the Allis's new. He ran dual exhaust up both sides of the hood. Exhaust came out and up about 6inches or so then a small muffler then
another piece of pipe with mini rain caps on top. Looked and sounded pretty cool. Of course he had it all decked out too. I think that he probably kept J.C. Whitney in business back then. LOL. It had the same rear tires that yours has on it , but he changed out the fronts to the narrower rims with ribbed tires. Sure wish I had a picture of it, but it is long gone now. The only main problem with the dual stacks it that he had to keep his trees trimed up so they didn't tare them off.
Mark
#73 olcowhand ONLINE
  • 41,098 Thanks
  • 31,402 posts
Posted July 17, 2011 - 02:06 PM
I took the hood off for now, until I get the exhaust built. It will be a single exhaust pipe exiting just in front of the engine dipstick, so the hood will not have to be cut. That will be a while, till I can get to an exhaust shop.
#74 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted July 17, 2011 - 02:12 PM
You got that right!!! 430 wants no part of that brute...
#75 MH81 OFFLINE
Posted July 17, 2011 - 02:20 PM
Daniel, nice 720. Glad she's about ready to move on her own.
