How big is too big for Cub 1811
cub 1811 gannon box scraper
14 replies to this topic
#1 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,841 Thanks
  • 1,584 posts
Posted June 17, 2017 - 04:05 PM
I've seen some GT's online that have a 48" box scraper on them.  I know of a 48" Gannon Earthcavator that I'm interested in but I don't know if it will be to big for my Cub 1811.  What do you think?  Will it work?
  • kjmweld said thank you
#2 KennyP ONLINE
  • 40,928 Thanks
  • 47,123 posts
Posted June 17, 2017 - 05:01 PM
Should! I have a 50" box blade that weights 140 lbs for Alice!
  • Mark 149 J. and kjmweld have said thanks
#3 kjmweld ONLINE
kjmweld
  • 507 Thanks
  • 364 posts
Posted June 17, 2017 - 05:10 PM
Kenny, does your box blade have the scarifiers on it? If so how many? and can you pull it thru the dirt easily still? Both mark149 & myself both (I'm assuming) realise working just a box blade that width would work ok, but not too sure on ripping hard packed dirt apart with that width. At least that's my concern anyway.
  • KennyP and Mark 149 J. have said thanks
#4 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,841 Thanks
  • 1,584 posts
Posted June 17, 2017 - 05:16 PM
That is exactly what I was thinking!
  • KennyP and kjmweld have said thanks
#5 shorty ONLINE
shorty
  • 5,836 Thanks
  • 5,417 posts
Posted June 17, 2017 - 05:24 PM
A priority for me would be to cover the tire width. Kenny's sounds great with the weight of it.
#6 KennyP ONLINE
  • 40,928 Thanks
  • 47,123 posts
It has 6 teeth on it and pulls them just fine through packed gravel. Just gotta have the traction to make it pull!
  • shorty, Mark 149 J. and kjmweld have said thanks
#7 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,841 Thanks
  • 1,584 posts
Posted June 17, 2017 - 05:30 PM
Sounds like it might work after all.
Does anybody know how much the 42" Gannon Earthcavator weighs?  I know that the 1811 can lift at least 300 pounds but I don't know how much a 48" would weigh so if I know what a 42" weighs I might be able to determine what the 48" weighs (does that make sense?)
#8 olds45512 OFFLINE
olds45512
  • 1,409 Thanks
  • 701 posts
Posted June 17, 2017 - 05:38 PM
Your 1811 will handle that Gannon just fine, lots of guys on the Cub forum have them.
#9 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,841 Thanks
  • 1,584 posts
Posted June 17, 2017 - 06:15 PM
That's good to know.  Thanks
#10 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,841 Thanks
  • 1,584 posts
Posted June 18, 2017 - 12:36 AM
I found some more information about the Gannon Earhcavator.
  • KennyP, WrenchinOnIt and kjmweld have said thanks
#11 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,841 Thanks
  • 1,584 posts
Posted June 18, 2017 - 12:45 AM
One thing that stands out when I look at this chart is the change in weight from a FD 42" weighs 159 lbs. while the FDH 42" weighs 410lbs. and the FD 48" weighs 462 lbs..  462 lbs on a cat 0 lift arms seems like a lot of weight.  It looks like Gannon made a lighter weight version of the Earthcavator for the GT's but once you step up to the Cat 1 version they made them with a lot more steel to withstand the higher hp and torque of the bigger tractors.
#12 kjmweld ONLINE
kjmweld
  • 507 Thanks
  • 364 posts
Posted June 18, 2017 - 05:53 AM
Thanks for posting that documentation paperwork about the gannons. I hadn't previously ever came across that particular piece of literature before. Very interesting.
  • Mark 149 J. said thank you
#13 KennyP ONLINE
  • 40,928 Thanks
  • 47,123 posts
Posted June 18, 2017 - 06:35 AM
That is heavier than I thought. I am going to save that pic and make it into a PDF for the Manuals section.
  • WrenchinOnIt, Mark 149 J. and kjmweld have said thanks
#14 Oak OFFLINE
Oak
  • 64 Thanks
  • 56 posts
Posted June 18, 2017 - 09:43 AM
The 400lb + one says it is for a Kubota & Ford and they didn't make a cat 0 48" model. I think 42" is the largest I've seen. Post up some pics if you can.
Edited by Oak, June 18, 2017 - 09:47 AM.
#15 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,841 Thanks
  • 1,584 posts
Posted June 18, 2017 - 10:36 AM
This Gannon is not a Cat 0 but a Cat 1.  I was going to switch it to a Cat 0 if a bought it. According to the chart they didn't make a 48" Cat 0 only a Cat 1.    Here is the ID tag.
00202_jDyALbY1vHe_600x450.jpg00N0N_lMrQbAyYbhG_600x450.jpg00U0U_dT9i2t6HwY2_600x450.jpg
Edited by Mark 149 J., June 18, 2017 - 10:38 AM.
Also tagged with one or more of these keywords: cub, 1811, gannon box scraper
