Troy Bilt GTX Loader Build
bolens loader fel troy bilt gtx pf engineering
35 replies to this topic
#31 mmmmmdonuts OFFLINE
mmmmmdonuts
  • 66 Thanks
  • 38 posts
Posted October 15, 2017 - 08:55 PM
Made a little more progress this weekend. Got the arms test fit on the tractor before I weld in the cross beam which is the next step. Decided to mount the pump in the front so I was working on a pump mount along with with where the tower braces will mount as well. Hopefully will continue to make progress in the upcoming weeks but I also need to get prepared for winter.
  • olcowhand, KennyP, Cvans and 2 others have said thanks
#32 Dooolz91 OFFLINE
Dooolz91
  • 7 Thanks
  • 3 posts
Posted October 19, 2017 - 05:08 PM
Well fellas,here she is,all cleaned up and mine now! I was wrong however, it's got 450hrs on it but still in primo shape and worth every penny spent for it. It ran leaving his house but I still like to go through my stuff,so she's got a fresh tune up with new fuel,fuel filter,oil change ,air filter,plugs,ect...
Gotta say it's not your average riding mower,can definitely tell it's more of a beast and I can see it working out quite nicely. Tks for the posts here,definitely gave me a little push into getting it now! Now for the attachment hunt!
  • KennyP, Cvans, TomLGT195 and 2 others have said thanks
#33 Cvans ONLINE
  • 6,468 Thanks
  • 6,061 posts
Posted October 19, 2017 - 09:11 PM
That's still low hours and yes they are a very nice machine. The power steering is neat but takes a little getting used to.
Edited by Cvans, October 19, 2017 - 09:12 PM.
#34 mmmmmdonuts OFFLINE
mmmmmdonuts
  • 66 Thanks
  • 38 posts
Posted October 23, 2017 - 11:55 AM
Congratulations on the tractor Dooolz91. I think you will end up loving the machine and work hard for you for many years.
#35 mmmmmdonuts OFFLINE
mmmmmdonuts
  • 66 Thanks
  • 38 posts
Posted November 04, 2017 - 12:41 PM
So little progress has been made lately. I managed to weld the cross beam and gussets to the arms. The reason it has been going a little slow is I had to modify the subframe because I got a new addition to the tractor as seen below. I got fortunate enough that it was about 45 minutes from me and I managed to scoop it up. Very excited...
I am also looking more at putting the pump in the middle like cvans did. It is a very very tight against the subframe. It looks like I may have about an 1-2 inches behind the pump but that's where the pump outlet and drain port come out and I don't know if I have enough room with elbows or not. I will have to do more measurements and connect everything to verify if it will fit or not.
Edited by mmmmmdonuts, November 04, 2017 - 12:42 PM.
  • KennyP and TomLGT195 have said thanks
#36 KennyP ONLINE
  • 37,580 Thanks
  • 45,541 posts
Posted November 04, 2017 - 01:46 PM
I have one of those. Very handy at times!
Also tagged with one or more of these keywords: bolens, loader, fel, troy bilt, gtx, pf engineering
