Broken spring ,Where the heck does it go?
1 reply to this topic
#1 Reed Breneman OFFLINE
Reed Breneman
  • 2,043 Thanks
  • 709 posts
Posted June 13, 2017 - 05:35 PM
Its a poulan pro (made by husqvarna) with a hydrostat trans that customer says gets real lurchy then stops moving,,If he waits a minute it will usually start going again,Last time it didnt.After I cleaned out about a bale of hay from under the battery box over the rear end I see this broken spring ,Wonder if thats the problem or like I figure the hydro is shot
#2 boyscout862 ONLINE
  • 12,824 Thanks
  • 9,155 posts
Posted June 13, 2017 - 06:38 PM
Looks like it goes to the same post as the one just above it, when you get a replacement. Probably holds it in neutral. Good Luck, Rick
  • Reed Breneman said thank you
