Large Frame Fan Question
2 replies to this topic
#1 Husky ONLINE
Husky
  • 1,186 Thanks
  • 1,057 posts
Posted June 12, 2017 - 07:29 AM
Would anyone know if the hydro fan on an 1886 would fit on an HT23 or what the difference may be. The part numbers on the 1886 and HT23 fan are different. I had that question come up from someone and based on the part numbers I'd have to say there is a difference between the two. Thank you for any help on this.
  • blackjackjakexxix and bprzyw have said thanks
#2 ClassicBolens ONLINE
ClassicBolens
  • 1,357 Thanks
  • 490 posts
Posted June 12, 2017 - 07:58 AM
1250, 1455, 1476, 1477, and 1886-01 thru 1886-04 used a 4 blade metal fan, part # 1719006 which is press fitted to the driveshaft. 1886S-05, 1886S-06, HT18, HT20 all used part # 1724027, which is a 4 blade plastic fan. HT23 uses part # 1738427 which is a 5 blade plastic fan. The plastic fans are held to the drive shaft with a set screw.
  • Bolens 1000, blackjackjakexxix, boyscout862 and 3 others have said thanks
#3 Husky ONLINE
Husky
  • 1,186 Thanks
  • 1,057 posts
Posted June 12, 2017 - 12:32 PM
Excellent, thank you!
