Bolens 1050. 1st gear problem. UK
10 replies to this topic
#1 ollieinDevon OFFLINE
ollieinDevon
  • 3 Thanks
  • 14 posts
Posted June 10, 2017 - 06:00 PM
Hi Chaps just recently acquired a bolens 1050 Here in the Uk.
Spares or repair.
1st gear is gone.
No High select.
Stuck with what to do as parts not easy to find here in the Uk. As most people probably know.
Can anyone in the Uk Help me out is really what I'm asking with parts ?
#2 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3,048 Thanks
  • 2,140 posts
Posted June 10, 2017 - 06:25 PM
Welcome aboard,sure those guys over your way can help
Edited by blackjackjakexxix, June 10, 2017 - 06:26 PM.
#3 ollieinDevon OFFLINE
ollieinDevon
  • 3 Thanks
  • 14 posts
Posted June 10, 2017 - 06:32 PM
Hi! Let's Hope so.
Here is what my 1050 gears look like..
  • Oldford said thank you
#4 dtsh OFFLINE
dtsh
  • 248 Thanks
  • 169 posts
Posted June 10, 2017 - 08:51 PM
Looks like all the teeth are gone on the input shaft. Assuming I am correct, it's the same part (1713442) as the input shaft on the 3 speed transmission as well. I am in the process of replacing the one in my 750 currently. I was fortunate enough to find a NOS one from one of our vendors for my project.
I used 29 Chev's Return to Service thread as a guide in doing mine.
I took some pictures of mine in this post of my Bolens Husky 750 - Transmission thread.
I suspect if you ask our vendors and make a post in the wanted section you should be able to find one. I'd offer my old one, but it's only nominally better than the one you have.
Edited by dtsh, June 10, 2017 - 08:52 PM.
#5 ollieinDevon OFFLINE
ollieinDevon
  • 3 Thanks
  • 14 posts
Posted June 11, 2017 - 06:36 AM
29 chev showed me the same thing.
Very helpfull.
2nd and 3rd do have Wear.
so a bolens 750 input shaft 3 Speed.would suit as a replacement?
#6 BolensChrisUK OFFLINE
BolensChrisUK
  • 519 Thanks
  • 242 posts
Posted June 11, 2017 - 08:25 AM
Hi Ollie,
I have a 1050 which needs love & was planning to sort. I have plenty to do so would sell it  for spares or repairs if your interested
The gearbox is good I am sure but the steering is broken
I am in the UK :wave: In Sussex
Chris
  • Oldford and ollieinDevon have said thanks
#7 dtsh OFFLINE
dtsh
  • 248 Thanks
  • 169 posts
Posted June 11, 2017 - 11:55 AM
Very helpfull.
A 750 would be hard to find as they were made only one year. The input shaft (Bolens part # 1713442) in the 3 speed found on many of the older Bolens Husky tractors, such as a 600, 650, 750, 800, 900, etc) would work in the 6 speed ones too as it's the same part (1713442)
Edited by dtsh, June 11, 2017 - 11:58 AM.
  • Bolens800uk said thank you
#8 ollieinDevon OFFLINE
ollieinDevon
  • 3 Thanks
  • 14 posts
Posted June 11, 2017 - 01:07 PM
That's definitely helpfull advice.
Thankyou for that.
#9 heliosuk OFFLINE
heliosuk
  • 183 Thanks
  • 146 posts
Posted June 11, 2017 - 02:42 PM
Hi Ollie,
Chris
Might be interested Chris, what you looking for ££ wise?
#10 BolensChrisUK OFFLINE
BolensChrisUK
  • 519 Thanks
  • 242 posts
Posted June 11, 2017 - 02:46 PM
See what Ollie says 1st Phil :thumbs:
#11 heliosuk OFFLINE
heliosuk
  • 183 Thanks
  • 146 posts
Posted June 11, 2017 - 03:00 PM
Ollie,
Have this and possibly another two to choose from but they have not had the covers removed yet so condition is unknown at the moment. Had the same issue on my current G14 but re-built the gear like Chev 29 did. So far so good but the box is noisy with the gears meshing. I've overfilled the box with oil as the level the gear train runs is to me too low and hence is significantly quieter. I also have a magnet glued to the drain plug and change the oil every two hours of running. The debris I weigh each time which shows the box after the repair is bedding in.
The one I have is not ideal but it works. Welcome to it if you want it.
  • Oldford and Bolens800uk have said thanks
