Tire pressure
7 replies to this topic
#1 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted June 07, 2017 - 12:21 PM
How much pressure in 18x9.50 x8 ag tire.?
#2 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted June 07, 2017 - 01:47 PM
max air pressure should be on the side of tire
  • Macmagee said thank you
#3 propane1 ONLINE
propane1
  • 8,723 Thanks
  • 4,130 posts
Posted June 07, 2017 - 02:50 PM
I would put 8 to 10 psi. But that's just me and my idea. Everybody is different.
Noel
#4 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted June 07, 2017 - 02:56 PM
It says max load 565 lbs @ 50 lbs.
#5 dodge trucker ONLINE
dodge trucker
  • 2,436 Thanks
  • 3,125 posts
Posted June 07, 2017 - 03:06 PM
Depends on how many plies the tires are. 2 ply won't take as much as a 4 ply.
That, and the application needs to be considered. Is there a tiller hanging off the back? Loader on the front? The guy who made the tires don't know that. Just because a tire says that it can take so many pounds doesn't mean you gotta run it.
Take 2 plys off and replace with 4 plys the machine still weighs the same as it did with the old 2 plys on there.
#6 tater195 ONLINE
tater195
  • 2,197 Thanks
  • 1,412 posts
Posted June 07, 2017 - 03:12 PM
since this is in the pulling forum, I would say it depends on what kind of track, track condition, type of sled, weight of sled, tractor HP, weight and class.... so just take a guess and go from there. Find a club having a test and tune and make a few pulls and adjust the pressure and see what it does. Every track will be a little different, so take notes.
#7 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted June 07, 2017 - 07:03 PM
   I would think for pulling you would want as little as possible and still maintain tire shape, give yourself as much traction as possible.  but I have never pulled so I don't know.  tater is right, find a club and give it a try
#8 propane1 ONLINE
propane1
  • 8,723 Thanks
  • 4,130 posts
Posted June 07, 2017 - 08:35 PM
If ya go below 6 psi. It has the possibly to spin the wheel, while the tire stays still. Breaking the bead.
Must be a 6 ply tire with those ratings. I'm only guessin.
Noel
