So much for stupid proofing.
21 replies to this topic
#16 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,171 Thanks
  • 5,658 posts
Posted June 07, 2017 - 07:36 AM
Remove the plugs and try turning it over by the fan belt.  #1 should be marked on the distributor and in the front cylinder is #1,always has been like the others have said.  Like Eric said, firing order is 1-3-4-2 on 4 cyl. engines.  8 cyl. is 1-8-4-3-6-5-7-2.
Only on GM's that is...
#17 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,171 Thanks
  • 5,658 posts
Posted June 07, 2017 - 07:37 AM
There is instructions right there in front of your nose on the coil.
1 2 V
Number one cylinder to the left, number two is to the right of it.
If you spin the coil around, it probably tells you how to tell three and four apart.
This same method works on Dodge truck engines to differentiate between the straight six and a V8.
Grab ahold of the left cylinder's spark plug wire and if it jolts ya while the timing mark goes by that's #1!
  • KennyP, js5020 and LilysDad have said thanks
#18 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 12,961 Thanks
  • 9,609 posts
Posted June 07, 2017 - 10:56 AM
Be sure to take a video.
  • MH81 and js5020 have said thanks
#19 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,114 Thanks
  • 1,207 posts
Posted June 07, 2017 - 11:10 AM
Boy, with friends like this who needs enemies'!!! :D
I'm surprised they haven't told you to check the muffler bearing to see if it's working!
#20 MH81 OFFLINE
Posted June 07, 2017 - 03:26 PM
Changed them last year.
CAT talked me thru it
  • EricFromPa, tractorgarden, LilysDad and 4 others have said thanks
#21 Cvans ONLINE
  • 6,450 Thanks
  • 6,051 posts
Posted June 07, 2017 - 03:33 PM
This is not always true. Some of the Ford V-8's were, 1-5-4-8-6-3-7-2  and International is timed off of #8 cylinder
There could be others but these are the ones that come to mind.
  • MH81 and MolonLabe have said thanks
#22 MH81 OFFLINE
Posted June 07, 2017 - 07:37 PM
Well, the distributor is 180 out.
That 'splains it.
Thanks guys.
  • Cvans and MolonLabe have said thanks
