Ariens 934 steering wheel removal
1 reply to this topic
#1 ponch OFFLINE
  • 1 posts
Posted June 06, 2017 - 02:30 PM
I must remove the steering wheel on my model 934005 Ariens tractor to get at the electricals under the dash...but I can't get it off. A parts diagram shows a pin holding it on, which I've removed, and a bolt in the hub of the wheel which I don't seem to have. Looking down through the hole at the center of the wheel, all I see is what appears to be the flat top of a shaft. I've soaked it in pen. oil but it doesn't budge. Any help would be appreciated.
#2 Piddler2 OFFLINE
  • 5 Thanks
  • 14 posts
Posted June 06, 2017 - 04:09 PM
I had same problem.Used a cheese cutter bearing separator tool from harbor freight.Put it on the bottom of steering wheel to evenly distribute force.Then you can use a two jaw puller on it.Hope this helps
