Panzer help!
21 replies to this topic
#16 Zhobbs OFFLINE
Zhobbs
  • 3 Thanks
  • 9 posts
Posted June 06, 2017 - 03:18 PM
More pictures can get more later as well.
  • Mark 149 J. said thank you
#17 Canawler OFFLINE
Canawler
  • 1,951 Thanks
  • 1,806 posts
Posted June 06, 2017 - 03:31 PM
Very cool custom unit. Definitely not a Panzer though it sure looks to be modeled after one. The deck is Simplicity.
This should probably be moved to a different sub-forum for further identification if a moderator sees this.
Edited by Canawler, June 06, 2017 - 03:33 PM.
  • cootertom said thank you
#18 EricFromPa ONLINE
EricFromPa
  • 4,162 Thanks
  • 3,345 posts
Posted June 06, 2017 - 06:27 PM
I had 1 that could of been home made to but there was a few things on it that were definitely not home made. And the way it was put together just didn't look home made.
It had an old vertical shaft points ignition 10hp briggs on it with pull and electric start. Ross steering box with the steering arm sticking out the left side of the tractor and a nice heavy drag link. Cast iron front axle with automotive type bearings and spindles. A small 3 speed with reverse peerless? gear box with chain drive rear. Rear had a small differential with a large sprocket and a mechanical disk brake caliper that used the sprocket as a brake disk.
Very heavy built tractor.Frame was made out of heavy wall 1 1/2" x 3" rectangle steel tubing.
The Hood and grill looked very very similar to your tractor.
It could be possible that there are a few prototype tractors floating around. Some of this stuff looks way to thought out and refined to be home made.
Sadly it sat outside for many many years.Everything on it was locked up tight except the engine. Which I did get running but when I popped it in gear the gear box blew apart. I know I should of kept it but I was around 14 and it was my 1st tractor. I did use the engine in a old Snapper RER that my uncle gave me though.Made a bunch of $$ mowing neighbors yards and bought me an awesome bicycle.Slightly used 1982 GT Pro 20" stunt bike with pegs and HAND BRAKES. Yep Hand Brakes. My 1st bike with them and my last bike with the old foot brake. The good old days how I miss them lol.
#19 pacubcadet OFFLINE
pacubcadet
  • 58 Thanks
  • 56 posts
Posted June 06, 2017 - 07:42 PM
kinda looks like a bush hog but I don't much about them
Minus the way the headlights are situated, I dont think it's a bush hog. this is a good one. No idea or any kind of plates anywhere???
#20 Zhobbs OFFLINE
Zhobbs
  • 3 Thanks
  • 9 posts
Posted June 07, 2017 - 09:38 AM
Ok just an update! I believe it's a popular mechanics kit mower. Are these worth anything?
#21 Zhobbs OFFLINE
Zhobbs
  • 3 Thanks
  • 9 posts
Posted June 07, 2017 - 09:56 AM
Magnatrac gt maybe?
#22 jabelman OFFLINE
jabelman
  • 2,242 Thanks
  • 1,605 posts
Posted June 07, 2017 - 10:11 AM
not much
