What Grease for Rotory Gearbox
3 replies to this topic
#1 Bad_Custom_6 OFFLINE
Bad_Custom_6
  • 1 Thanks
  • 3 posts
Posted June 06, 2017 - 07:33 AM
Was trying to cross ref the grease listed in the manual and coming up with nothing
What grease are you using for the sears Rotary Mower gearbox 917.99620?
I was thinking something like the John Deere Golf and Turf Cutting Unit Gun Grease - TY25083 or the Special-Purpose Corn Head Gun Grease - AN102562
here is a picture with the gearbox in question
#2 chieffan OFFLINE
  • 11,374 Thanks
  • 7,118 posts
Posted June 06, 2017 - 11:57 AM
80W - 90W gear oil would be my guess.  That is what I run in my gear boxes including a Sears Tiller and gear drive tractor rear ends.  Be much cheaper than anything JD has to offer.
Edited by chieffan, June 06, 2017 - 11:58 AM.
  • Bad_Custom_6 said thank you
#3 Bad_Custom_6 OFFLINE
Bad_Custom_6
  • 1 Thanks
  • 3 posts
Posted June 06, 2017 - 04:01 PM
The JD Grease isn't so bad less than $4.00 a tube.
The Rotary Deck manual calls out E.P. lithium grease part #5801, but haven't been able to find a cross reference
The PO filled them with them gear oil that seeped out all over my garage floor.
Edited by Bad_Custom_6, June 06, 2017 - 04:24 PM.
#4 GardnMastr OFFLINE
GardnMastr
  • 399 Thanks
  • 203 posts
Posted June 06, 2017 - 04:51 PM
Corn head grease is a good choice. It is what is called a non channeling grease. It is between the fluidity of 80w-90 and the non fluidity of grease. Meaning, it will move around, but not so liquid it will run past some worn seals.
