Top Paint layer removal techniques?
paint removal acetone lacquer thinner
19 replies to this topic
#16 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted June 07, 2017 - 07:59 PM
Sounds like you already have your method of removal picked, but if you are still open to suggestions, here is mine. I use 1500 wet/dry sandpaper like suggested above, however I use WD-40 instead of water. I've used this method numerous times with great results in removing paint from original decals. The WD-40 will act like a lubricant and won't allow the sandpaper to cut too fast. The WD-40 will also aid in softening the rattle can paint but won't destroy your original paint underneath. Good Luck to you and don't forget to keep us updated on your results.
  • TomLGT195 and Mark 149 J. have said thanks
#17 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,331 Thanks
  • 1,317 posts
Posted June 07, 2017 - 09:00 PM
I'll give that a try as well.  It can't hurt!
#18 jabelman OFFLINE
jabelman
  • 2,216 Thanks
  • 1,589 posts
Posted June 08, 2017 - 04:56 AM
I would not recommend this if you plan to repaint it someday, you will have more fish eyes than you can imagine
  • Sawdust and Mark 149 J. have said thanks
#19 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,331 Thanks
  • 1,317 posts
Posted June 08, 2017 - 10:08 AM
Wow! Thanks for the warning!
I take it you found this out the hard way?
#20 jabelman OFFLINE
jabelman
  • 2,216 Thanks
  • 1,589 posts
Posted June 08, 2017 - 10:47 AM
no, i worked, summers at body shop years ago, was drilled in our heads how much oil/silicon sprays would ruin your day
  • Mark 149 J. said thank you
Also tagged with one or more of these keywords: paint, removal, acetone, lacquer, thinner
