K361 convert to K341
k361 k341 k321
5 replies to this topic
#1 1010Deere OFFLINE
1010Deere
  • 1 posts
Posted June 05, 2017 - 10:33 AM
Trouble with my Power King's K361 running right, spews some gas out the carb, and having enough power.
Sometime the engine runs ok but never to level that I think this engine should. Since so many of the engine parts seem to be the same, is it possible to convert this engine to one of the less troublesome flathead K341/K321 or is it more trouble than what it's worth?
The head parts are what are hard to find on this engine but not the lower half, and if I will have a less reliable engine than the K341 or K321 I would just as soon bite the bullet now!
  Any suggestions?
#2 glgrumpy OFFLINE
  • 8,105 Thanks
  • 7,546 posts
Posted June 05, 2017 - 02:58 PM
Don't think change ce of convert, but plenty of K e vines will interchange. K241 is most durable. I have put in 16 single in past.Join PK forum on facebook, lots of parts guys there.
#3 Billy M OFFLINE
Billy M
  • 552 Thanks
  • 488 posts
Posted June 05, 2017 - 03:38 PM
I have an Ariens GT18 with a K361 in it.  It was running just like yours.  It had a hole in the float in the carb.  The float was gas-logged and wasn't doing it's job.  I replaced the float and she ran like a champ.  Still does to this day.  I mow with it every week.  If the rest of the engine is still good, I would check the little things before looking into a re-power.  The K361 is a good engine if you keep it clean and keep your revs up to keep it cool.  I've seen plenty of them with grass-filled fins on the heads.  They usually end up dropping a valve seat.
Edited by Billy M, June 05, 2017 - 03:40 PM.
  • Gtractor said thank you
#4 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 11,800 Thanks
  • 8,925 posts
Posted June 05, 2017 - 05:18 PM
This is not English GL. I can't read it.
I would do a more thorough job of troubleshooting your engine first. As Billy M implies, it doesn't take much to make an engine run bad. Lots of folks on here are happy to help.
#5 MNGB ONLINE
MNGB
  • 1,568 Thanks
  • 1,128 posts
Posted June 05, 2017 - 06:09 PM
Hi 1010deere, no it can not be converted to a 321 or 341 there are few if any parts that are the same, I have a K361 in my 84 PK it is a very nice running engine but every year (in the fall) I remove the cooling tins and clean the cooling fins check the headbolt torque and must sure the cylinder head is clean no built up crude on the head.
Your problem could very well be the carb one easy thing to check and causing a lot of run problems is the carb throttle shaft to check it just grab it at the top (with engine off) and wiggle it if it more at all its leaking air this causes erratic engine running. No one is mfg aftermarket  carbs for the k361, but there are throttle shaft bushings and a new throttle shaft available. It sounds like the carb needs a complete rebuilt and not a needle seat and gaskets.
#6 glgrumpy OFFLINE
  • 8,105 Thanks
  • 7,546 posts
Posted June 05, 2017 - 08:05 PM
Lily's Dad.  Wrote that on my phone, just getting up, AND, that is NOT what it said when I hit send!  Darn phone always make diff words for you, plus guess missed couple of letters there and .......it goes on and on.  There, said my rant, now quit picking on me.  Just wanted to tell guy, get another K engine, they are all over and the PK group on Facebook is just full of guys parting these things all the time and have what he wants. :shoot3:
