AC B1 trans drive pulley size
9 replies to this topic
#1 hddlh OFFLINE
hddlh
  • 45 Thanks
  • 80 posts
Posted June 05, 2017 - 07:48 AM
Went to replace drive belt and the one I bought is way small.  The belt I bought is 42" OC and one I took off is 48" OC.  Looking at the drive pulley on transmission it does not look original, no paint.  It's 10" in diameter, I'm thinking someone changed it to slow tractor down, it doesn't go very fast even in third gear.  If someone could provide diameter of correct size it would be appreciated.  If I'm going in the wrong direction, feel free to turn me in the right one.
thanks
#2 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted June 05, 2017 - 07:53 AM
thanks
If someone dosent beat me to it, when i get home from school i can go measure my pulley. Mine does not have paint, i dont believe they are supposed to.
#3 SimplyRad OFFLINE
SimplyRad
  • 1,110 Thanks
  • 843 posts
Posted June 05, 2017 - 08:38 AM
That reduced drive was an option. I had gotten one for the 2210 I had in 1968 to slow it down some for tilling.
#4 jimmy G ONLINE
jimmy G
  • 1,197 Thanks
  • 780 posts
Posted June 05, 2017 - 11:19 AM
The first two are my B1,second two are my landlord,hope this helps
  • hddlh and 637Yeoman have said thanks
#5 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted June 05, 2017 - 11:51 AM
I have what i belive is a reduced drive pulley, but im not sure. It has triangles cut in it. Is there a way of knowing?
#6 SimplyRad OFFLINE
SimplyRad
  • 1,110 Thanks
  • 843 posts
Posted June 05, 2017 - 01:04 PM
I haven't seen that tractor since 1978 so I don't remember too much about it today.
  • 637Yeoman said thank you
#7 B10Dave OFFLINE
B10Dave
  • 780 Thanks
  • 348 posts
Posted June 06, 2017 - 05:10 PM
10in. pulley is to slow tractor for tilling. Standard for mowing should be a 6in or maybe a 7in. If I recall correctly the 42in belt fits a 6in pulley. But I may be mistaken.
  • hddlh said thank you
#8 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted June 06, 2017 - 06:49 PM
   pretty sure stock is 6" od, I run 7" on mine to slow it down just a touch.  makes it a little more user friendly.
        Pete
#9 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted June 07, 2017 - 09:15 AM
Yeah, stock is 6" (42" belt).  The Low Speed kits were offered in 10" (for 7-9hp tractors, 49" belt) and 8" (for 10-12hp tractors, 45" belt).
#10 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,625 Thanks
  • 1,311 posts
Posted July 27, 2017 - 12:03 AM
6 inch was standard. 8 inch and 10 weres offered as an option on the 700/725 and B1. I have a factory 8 inch on my 700.
Edited by rustyoldjunk, July 27, 2017 - 12:05 AM.
