Sleeper trailer-6
7 replies to this topic
#1 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,878 Thanks
  • 1,850 posts
Posted June 17, 2011 - 06:36 PM
The roof is done so it's time to finish the sides.
The wood in the upper right front corner was rotted out from where the roof leaked.
The rotted wood is stripped out.
Luckily the ends of the 2x2 cross braces are still good.
I made up a new curved upper corner piece and put in a new 2x2 in the corner.
The openings for the two windows on the right side are framed up.
Dry fitting the windows on this side to make sure everything is OK.
The overall height of the camper is about three inches taller that it was so there is a gap above the rear panel.
This is filled in with strips of wood.
A piece of 1/2 inch plywood is extended straight back from the angled part of the roof to strengthen this area.
There are sections of 2x2 that angle down from the roof to the back wall.
The inside paneling will attach to these so the roof area will angle straight down to the back wall.
This gap between the paneling and the roof will be used to run the wiring from one side to the other over the door.
The window opening on the left side is framed up.
There is a piece of 3/4 inch plywood in the framing above the window area.
This is so I can mount the interior light and have room for the wiring to run to it behind the plywood support.
Making sure the window on the left side fits the opening.
The left side of the overhang had this small window in it.
I haven't decided if I'm going to put it back in or not yet.
The angled 2x4 brace for the overhang runs right thru the area where this window use to be.
#2 KennyP ONLINE
  • 37,543 Thanks
  • 45,533 posts
Posted June 17, 2011 - 07:01 PM
At least when you are done with it, you know it will be a 'trailer queen'. LOL Looking good, repairs look better than factory built.
  • jdcrawler said thank you
#3 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,878 Thanks
  • 1,850 posts
Posted June 18, 2011 - 12:04 PM
Talked it over with my wife last night and decided to go ahead and put in the small window in the overhang.
I had taken out the original window frame with it still altogether so all I had to do was trim it off and mount it.
The window sits higher and more forward to clear the angle brace.
#4 massey driver ONLINE
massey driver
  • 1,400 Thanks
  • 1,569 posts
Posted June 18, 2011 - 12:29 PM
Probably a good idea as it can sure get hot up that high in the camper and the more ventilation on a hot night sure will be welcomed glad to see the progress and how its comming along.Larry
#5 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted June 18, 2011 - 02:05 PM
Looking great Ray, glad you are making headway on the camper.
#6 mjodrey OFFLINE
Posted June 18, 2011 - 05:32 PM
Wow Ray,you are coming right along on that .:thumbs:
#7 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted June 18, 2011 - 08:30 PM
WOW what a great job. It maybe too nice to sleep in lol.
#8 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted June 18, 2011 - 08:45 PM
Ray you definitely don't waste any time getting er done. Coming out very nice :D
