GE Grass Cutters
9 replies to this topic
#1 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,428 Thanks
  • 5,617 posts
Posted June 03, 2017 - 06:37 PM
These are my 3 working grass cutters I have now.
   E15 has the Alltrax controller in it with a brand new set of Trogan T105 batteries. (center)
   E12M is in original condition and everything on it works, has the mid mount side discharge mower, with batteries that only give about 45 minutes run time cutting grass. (right)
   EGT200, my favorite, a survivor, almost everything works, has rear discharge mid mount mower, can cut grass for about 2 to 2-1/2 hrs. (left)
  • Alc, KennyP, tractorgarden and 10 others have said thanks
#2 daytime dave ONLINE
  • 4,967 Thanks
  • 6,598 posts
Posted June 03, 2017 - 06:45 PM
That's a great group Doug.  I think my batteries in the E20 are shot and I'll be taking them out soon.  Time to think about replacements.  Three deep cycles or six golf cart batteries.
  • DH1 and boyscout862 have said thanks
#3 KennyP ONLINE
  • 40,927 Thanks
  • 47,123 posts
Posted June 03, 2017 - 06:56 PM
Nice crew, Doug!
#4 TomLGT195 OFFLINE
TomLGT195
  • 4,051 Thanks
  • 2,901 posts
Posted June 04, 2017 - 05:44 AM
Nice quiet herd.
  • DH1 and KennyP have said thanks
#5 Oldford OFFLINE
Oldford
  • 1,135 Thanks
  • 786 posts
Posted June 04, 2017 - 06:23 AM
Could someone give a description of using the front mount deck, pros and cons.  I like the idea of the electric tractors but need some motivation to try my luck with the electronics part...
  • DH1 said thank you
#6 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,428 Thanks
  • 5,617 posts
Posted June 04, 2017 - 06:50 PM
IMO the Quality of cut with the Front mower is better, the deck follows the contours of the lawn independent of the tractor, also you can get under stuff better with it. Deck can be flipped up for cleaning or to service.
The mid mount mower also follows the contours like the front mount but doesn't do as good a job as it only rides on the rear roller, doesn't have the front casters wheels, mid mount can cut around stuff better and takes up less room in the garage.
  • KennyP, Cvans, CRFarnsworth and 1 other said thanks
#7 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,178 Thanks
  • 2,256 posts
Posted June 04, 2017 - 07:01 PM
Nice line up!
Is the  E15 the one you plow with?
This weekend I finally got around to cleaning, sanding, and painting the mower deck for my E14.  It is my back up mower.
I won't mow with it again until I've been to a few shows with it.   Rick
#8 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,428 Thanks
  • 5,617 posts
Posted June 04, 2017 - 07:09 PM
Nice line up!
The E15 is the one I have taken to plowdays but the EGT200 plows just as good and believe it or not the E12M can pull the plow in first gear.
I wouldn't be afraid to mow with your E14, take it to the shows with some grass clippings on it, people will see that it works and looks good.
  • KennyP, CRFarnsworth and Oldford have said thanks
#9 Oldford OFFLINE
Oldford
  • 1,135 Thanks
  • 786 posts
Posted June 05, 2017 - 03:25 AM
Thanks for the front mower pics looks real nice.  Does it come off and go back on easy?
Plow looks good too.  I used to know of a tiller for sale for one of these.   From time to time i kick myself for not taking the plunge.
Does the alltrax controller replace the original fuse box/circuit board?
#10 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,428 Thanks
  • 5,617 posts
Posted June 05, 2017 - 08:32 PM
Deck comes on or off in less than 1 minute.
I used the fuse block in mine, 3 fuses needed, 1for lights, 2nd for lift, 3rd for the Alltrax.
Plus the main fuse
Edited by DH1, June 05, 2017 - 08:33 PM.
  • Oldford said thank you
