Bolen Mower
24 replies to this topic
#16 bbuckler OFFLINE
bbuckler
  • 3899 Thanks
  • 3344 posts
Posted June 04, 2017 - 08:07 PM
  Running lean can be a vacuum leak. Don
Carbon on the spark plug show it running rich.
#17 bbuckler OFFLINE
bbuckler
  • 3899 Thanks
  • 3344 posts
Posted June 08, 2017 - 06:57 PM
Valves cleaned and lapped. Runs smooth no backfiring.
#18 bbuckler OFFLINE
bbuckler
  • 3899 Thanks
  • 3344 posts
Posted June 08, 2017 - 07:31 PM
#19 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 8089 Thanks
  • 4786 posts
Posted June 08, 2017 - 08:30 PM
Late to the party, but this is what Brandon has. I traded him it for a deck and Penncraft. I got this as a freebee but had no interest in it. It ran for me but was rough.
  • bbuckler said thank you
#20 bbuckler OFFLINE
bbuckler
  • 3899 Thanks
  • 3344 posts
Posted June 08, 2017 - 08:57 PM
I should've got a picture of the dried of snake in the blower housing. Probably what broke the fan
#21 bbuckler OFFLINE
bbuckler
  • 3899 Thanks
  • 3344 posts
Posted June 09, 2017 - 10:16 AM
I got a briggs non intek ohv that the fan might work on the intek
#22 bbuckler OFFLINE
bbuckler
  • 3899 Thanks
  • 3344 posts
Posted June 09, 2017 - 12:15 PM
I guess I didn't the set screw tight enough the rocker came loose and bent a push rod. Lucky I had a push rod and it running again
#23 bbuckler OFFLINE
bbuckler
  • 3899 Thanks
  • 3344 posts
Posted June 10, 2017 - 08:06 PM
New blades and I just finished mowing the pasture with it
#24 bbuckler OFFLINE
bbuckler
  • 3899 Thanks
  • 3344 posts
Posted June 11, 2017 - 12:32 PM
I finish mowing today but it did stall twice but there was some thick grass and weeds I cut today.
#25 bbuckler OFFLINE
bbuckler
  • 3899 Thanks
  • 3344 posts
Posted June 16, 2017 - 09:42 PM
Mowed the frontyard today went to put it up and it acted like it was starving for gas so I pulled the plug and it looked like it was running lean. Also the spark plug wire fell off but I got another coil I'm going to clean the carb tomorrow and see if that helps.
