The paint rusted?
16 replies to this topic
#1 classic OFFLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted June 03, 2017 - 10:31 AM
I'm cleaning up the frame for the rusty Page tractor so I can get some primer on it. I'm using a wire wheel on a grinder along with sand blasting. Looking at the frame, it appears that all of the paint is gone and replaced by rust. When I started wire wheeling, the paint came through the rust. So don't shy away from those rusty tractors, they might not be as bad as you think.
  • Gtractor, MH81, KennyP and 2 others have said thanks
#2 chieffan ONLINE
  • 10,129 Thanks
  • 6,632 posts
Posted June 03, 2017 - 10:43 AM
Typical surface rust caused from being in a damp moist area.
  • boyscout862 and classic have said thanks
#3 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted June 03, 2017 - 11:35 AM
Awh come on, your gonna paint it!  :boo_hoo:
  • classic said thank you
#4 classic OFFLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted June 03, 2017 - 12:08 PM
Gotta stop mother nature from making a meal out of it, Luke. So many things need to be repaired or replaced, so it might as well get paint. I do like the rusty look, but this thing was pretty bad.
  • 637Yeoman said thank you
#5 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted June 03, 2017 - 12:33 PM
Could you continue with the wire wheel then clear coat over the existing paint?
#6 classic OFFLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted June 03, 2017 - 12:48 PM
I could have Luke, but I have to fabricate a hood for it and it would just look cobbed up. A lot of the paint is missing in many areas, too. Rust is too much of a pain to maintain and it never stops. There's an antique engine/tractor show in August at the same place where I bought the tractor. I'm going to bring it to the show all restored with a pic of it when it was in the auction.
#7 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted June 03, 2017 - 12:55 PM
I dont have a problem with restoration, when its something as rare, or as rough as your page was. Did all of them come with hoods like yours did, or were there some without?
#8 classic OFFLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted June 03, 2017 - 01:04 PM
Page tractors came with and without hoods depending on the model. Someone fabricated the hood on mine, so I will make one the same as what should be on it. I'll have to curl the sides up on a piece of sheet metal, notch it, bend it, then weld it. I'll cut the top and front to length once it's bent and welded. Here's a Page similar to mine with the correct hood.
  • 637Yeoman and Mark 149 J. have said thanks
#9 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,294 Thanks
  • 9,777 posts
Posted June 03, 2017 - 02:50 PM
You could duplicate fake rust.
#10 classic OFFLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted June 03, 2017 - 03:41 PM
I just finished hitting it with red oxide primer, does that count LD?
#11 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,294 Thanks
  • 9,777 posts
Posted June 03, 2017 - 04:26 PM
Sure, then just add some high lights of flat black, copper, and such.
#12 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,316 Thanks
  • 4,952 posts
Posted June 03, 2017 - 05:44 PM
That's called "distress" :wave:
#13 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,294 Thanks
  • 9,777 posts
Posted June 03, 2017 - 07:36 PM
No distress is when your ex girl friend runs her car keys down the hood of your car.
  • Gtractor and classic have said thanks
#14 dropped82 ONLINE
dropped82
    Nut Case
  • 2,497 Thanks
  • 1,817 posts
Posted June 03, 2017 - 08:49 PM
That's getting awfully specific.
Eric
  • LilysDad, classic and 637Yeoman have said thanks
#15 Chucktin OFFLINE
Chucktin
  • 38 Thanks
  • 48 posts
Posted June 04, 2017 - 05:58 AM
Experience talking?
Sent from my SAMSUNG-SM-N900A using Tapatalk
