FF 18 Independent drive?
4 replies to this topic
#1 Dfmooresr OFFLINE
Dfmooresr
  • 6 Thanks
  • 8 posts
Posted May 31, 2017 - 10:34 PM
I was driving my FF 18 across the field when it quit moving forward. When I put it in forward or reverse, the left rear tire would spin but not the right one. I wasn't high centered. I towed it out of the field. Once it hit the driveway, it drove on its own down the driveway. I don't know if both wheels were working or if one worked and the other just rolled along. Question, does each rear wheel drive independently? Can one wheel work while the other doesn't? What could be the problem?
#2 KennyP ONLINE
  • 37,400 Thanks
  • 45,453 posts
Posted June 01, 2017 - 05:57 AM
Check for a stripped hub first. This is the Peerless 2500, which is limited slip. If it's not the hub, you have internal problems. Lots of those out there.
  • Dfmooresr said thank you
#3 Dfmooresr OFFLINE
Dfmooresr
  • 6 Thanks
  • 8 posts
Posted June 19, 2017 - 11:08 PM
How much transmission fluid does a FF 18 hold?
#4 secondtry OFFLINE
secondtry
  • 1,676 Thanks
  • 1,279 posts
Posted June 20, 2017 - 12:04 AM
   If you check the manuals section. third tab from the left at the top of this page you can likely download a manual for your machine.I believe that tab is where I found the manual for my !8/6.Don
#5 KennyP ONLINE
  • 37,400 Thanks
  • 45,453 posts
Posted June 20, 2017 - 05:38 AM
I'm thinking around a gallon and a half, but it's been a while since I have changed fluid in one.
