Transaxel
6 replies to this topic
#1 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted May 31, 2017 - 08:17 PM
I took the transaxel out of my Murray tractor three speed to weld up the spider gears washed everything up welded gears, re- greased,put back together. The big pulley spins in neutral axels don't put the selector in first spin the big pulley and axels still don't turn, second, third same thing.am I missing something?
#2 tater195 ONLINE
tater195
  • 2,078 Thanks
  • 1,379 posts
Posted May 31, 2017 - 08:55 PM
sounds like a woodruff key fell out when you put it back together.
  • Macmagee said thank you
#3 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted May 31, 2017 - 09:03 PM
The axel wouldnt spin while in neutral, try turning the axle while its in gear, see if the pulley turns. I would need a picture to see if something is missing
#4 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted June 01, 2017 - 01:13 PM
Does not turn in gear either must have left out a key way.
#5 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted June 01, 2017 - 01:17 PM
Do the axles spin, but the pulleys dont? Because if you can spin the axles then you left out a key.
#6 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted June 01, 2017 - 03:08 PM
Yes the axels spin
#7 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted June 01, 2017 - 03:17 PM
Yes the axels spin
Take it back apart, and look to see where a key is missing. Good luck
