1959 Economy
10 replies to this topic
#1 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted May 31, 2017 - 09:06 AM
I went a bought this economy tractor recently and am looking for a copy of the manual and a parts list if they are available. It is a 1959 economy that isn't in the best shape now but the engine does start right up than dies out after a couple of minutes, when it is running it will shift and drive and seems to have been kept in decent condition mechanically.
here are some pictures from what I can tell it has the original engine.
  • Alc, Traill95, Coventry Plumber and 2 others have said thanks
#2 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,884 Thanks
  • 1,108 posts
Posted May 31, 2017 - 09:23 AM
Nice looking Powerking!
Have you checked in the "Manual" tab in the upper left side of this web site?  There are plenty of manuals for powerking tractors listed in there.
  • dlang94 and 637Yeoman have said thanks
#3 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted May 31, 2017 - 09:37 AM
Looked through it but didn't find anything for 1959 or within a year or two of it. Seems to be some sales brochures that would include the 1959 uploaded there.
  • 637Yeoman and Mark 149 J. have said thanks
#4 glgrumpy ONLINE
  • 8,505 Thanks
  • 7,857 posts
Posted May 31, 2017 - 03:26 PM
Not much in the manauls for them, more like parts diagrams maybe.  I'ld have to look on my thumbdrive to see how old they go, there is a list of ones available. I also believe that even if you get later one, most things are going to be the same.
#5 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,834 Thanks
  • 2,330 posts
Posted May 31, 2017 - 03:33 PM
Looks great
#6 pacubcadet OFFLINE
pacubcadet
  • 58 Thanks
  • 56 posts
Posted May 31, 2017 - 05:06 PM
Great looking economy
Sent from my iPad using Tapatalk
#7 MotorMike OFFLINE
MotorMike
  • 17 Thanks
  • 11 posts
Posted June 01, 2017 - 05:55 AM
dlang, theres a service manual available on the thumb drive for the Briggs 23FB engine. Also the 1957 Instruction manual will apply to your 1959 machine.
  • dlang94 said thank you
#8 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted June 01, 2017 - 10:26 AM
Can you send me the copies of those or a copy of the thumb drive?
#9 MotorMike OFFLINE
MotorMike
  • 17 Thanks
  • 11 posts
Posted June 01, 2017 - 10:58 AM
Heres the two files I mentioned earlier.
#10 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted June 01, 2017 - 01:38 PM
Thank you! They will come in handy.
#11 oldiron1 OFFLINE
oldiron1
  • 408 Thanks
  • 259 posts
Posted June 12, 2017 - 11:29 AM
As far as the engine dying after a couple minutes; I'd replace the points/condenser for starters and if that doesn't fix the issue, my hunch is the coil. Those engines have a "special" coil mounted behind the flywheel that are known for problems with age. It might be my luck, but I haven't had a Briggs engine of that vintage yet, that I haven't had to replace the coil on.
Good luck, nice looking original tractor there!
Rob
