a new toy
2 replies to this topic
#1 daniel_b OFFLINE
daniel_b
  • 96 Thanks
  • 89 posts
Posted May 29, 2017 - 08:21 PM
this may be just the thing for someone when you would like to save a web page for the information thereon,
In my case, I may 'save' the page as a "Web Archive, single file (*.mht)"
- or, I can also 'print' the page to my .pdf writer,
BUT,
in some instances, there is just to much "garbage" - [also known as: ads, links, pics, etc.]
I would then just copy out the parts I wanted, and paste it into note-pad, word-pad, or a word doc,
was just sort of time-consuming...
with this though, you can 'print' the page to a real printer on your pc,
OR, you can 'print' it to a .pdf writer,
and,
ALL THE "GARBAGE" IS GONE!!!  :dancingbanana:
DISCLAIMER:
I just found this a few days ago and haven't tested/used it very extensively, so, what can I say...
I HAVE been playing with it a good bit and it has worked awesomely so far...
there is also an option to download it, make it a button in your browser, whatever and so on...
or if you have a web-page, to install it there...
[that's how I found it, by clicking the 'print' button on a web-page]
the way I have been using it is just enter the web address/url at their site, and follow the prompts to print to my .pdf writer...
try it, if you find some "ulterior motives" - PLEASE be sure to post them...
  • ducky, Alc, KennyP and 3 others have said thanks
#2 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted June 01, 2017 - 10:49 PM
I kind of like that.  Will have to play with when I have some time.
#3 daniel_b OFFLINE
daniel_b
  • 96 Thanks
  • 89 posts
Posted June 09, 2017 - 07:42 PM
some more playin' - and found this,
If you "mouse around" on the page, you can 'edit-out' even more than is 'stripped-out'
This is a very "clean site" - so it is really hard to notice the difference.
figured I would use myself and this thread as the guinea-pig to attempt an example
for instance, on this page, I had my cursor on the pic that GTtalk uses for my avatar,
