Kohler k321 no spark...
6 replies to this topic
#1 Greasy6020 ONLINE
Greasy6020
  • 1,376 Thanks
  • 1,337 posts
Posted May 29, 2017 - 07:13 PM
Have a k321 sitting in a Massey 14, no spark...
Tractor has sat for some time... covered, and under a boat.
Something is also going clack clack clack when I turn the motor over, under power from the starter
Any ideas? It has me beat
Edited by Greasy6020, May 29, 2017 - 07:13 PM.
#2 JohnDeere110 OFFLINE
JohnDeere110
  • 215 Thanks
  • 91 posts
Posted May 29, 2017 - 07:18 PM
can you pin point where the "clack"ing is coming from?
#3 Greasy6020 ONLINE
Greasy6020
  • 1,376 Thanks
  • 1,337 posts
Posted May 29, 2017 - 07:27 PM
Not really... from the motor for sure, sounds like near flywheel etc
#4 JohnDeere110 OFFLINE
JohnDeere110
  • 215 Thanks
  • 91 posts
Posted May 29, 2017 - 07:37 PM
Well for the first question of no ignition, if you didn't already check spark plug for spark.
Check if the noise is coming from inside or outside the engine cause that will really change where you go from here on the engine.
  • Greasy6020 said thank you
#5 dodge trucker OFFLINE
dodge trucker
  • 2,297 Thanks
  • 3,014 posts
Posted May 29, 2017 - 08:27 PM
I just revived a K341 that had sat for eons, wound up with new everything in the ignition system, all was corroded beyond hope.  and got it running with the ignition switch unhooked, with a jumper to the +on the coil straight from battery and jumper cables directly to the starter, just now starting to go thru tractor wiring to see what-all is bad there.....
#6 Greasy6020 ONLINE
Greasy6020
  • 1,376 Thanks
  • 1,337 posts
Posted May 30, 2017 - 11:57 AM
I pulled the plug, and grounded it out on the sheet metal, no spark...
#7 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 12,970 Thanks
  • 9,615 posts
Posted May 30, 2017 - 03:20 PM
You might at least pull the flywheel shroud. It could be a mouse nest or anything.
