Hi, I just recently picked up a WD2-1000 that's seized. I am in the process of unseizing it but I'm going to need to get all new gaskets. Can anyone tell me what the best place to find parts for this engine is?
Unfortunately parts are NLA including gaskets, extensive internet searches, go to part guys, and several old dealers netted zilch, sorry. If LP Bolens doesn't see this post you can PM him , I believe he put a new crank in one awhile ago, maybe he sourced some gaskets. Good luck with your endeavor.
As wrenchingonit said just about all parts are NLA for this series, the only thing I carry any more are the air filters, everything else has been discontinued for years and most sources are dried right up.
You can buy gasket material in sheets. Plumb make a nice little gasket hammer that will mark the edges and holes real nice. Hole punch set and good scissors and your back in business. Might get by by re-using the head gasket if not destroyed. Good luck.
secondtry is rite use a soft copper sheeting for your head gaskets or anything that may get hot, shim stock works ok but is a bit harder than I like. just be carefull about the thickness, you can change the compression ratio pretty quickly that way.
Welcome to GTT. Try fleamarkets and Epay. Two years ago at a Tractor Swap Meet there was a guy who cleanned out the back of the family barn. There were boxes of NOS Wisconsin engine parts. Someone ahead of me grabbed most as I walked up. Try your local NAPA and any old dealers that are around. You never know what they have stored away. Good Luck, Rick
I have a complete wd2-1000 that was running when put away in my garage 15years ago. Was saving it for a project but never got around to it. I can't see me using it anytime in the near future so I could sell it whole if anyone wanted it? Justin
Felpro does offer sheets of gasket material that can be used to cut new gaskets from - other gasket manufacturers probably do as well - you should be able to get the material at a local auto parts store. Part # 2498 is shown as a gasket material suitable for head gasket applications. Attached are jpegs of two pages that show the various gasket materials that they offer - they do list a product that is suitable to be used for head gaskets. What some people will do is draw an outline of the head gasket including hole locations on a piece of plywood - then clamp the gasket material between it and another piece of plywood and drill the hole locations. You can also drill starter holes where holes for the combustion chamber will have to be cut out. Then the gasket material can be cut with aviation snips. Just a suggestion if you cannot find gaskets.
So the only reason the motor was siezed was because the flywheel rusted to the stator, the stator is shot but thats not really a big deal since it only charges the battery. I could put a small belt driven alternator on it in the future if i wanted. But i did open up the crank case just to make sure everything was okay inside. The inside was perfect until the mice ate through my covers and got inside so it now needs a good cleaning. Does anyone have an owners manual or an operators manual that i could look at?
I know this is an old post but I'm looking for these manuals as well.
Related Threads
Garden Tractor Forums
951.2K posts
49.3K members
Since 2010
