410/3.50 nobby tires with rims with 3/4 bearings
10 replies to this topic
#1 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted May 27, 2017 - 06:52 PM
Like the title says looking for a set let me know thanks.
#2 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,984 Thanks
  • 2,477 posts
Posted May 27, 2017 - 08:14 PM
Another dimension you need to specify is the width of the hub through the 3/4" bearings which you require.
Do you want 2-piece (split) rims with a separate hub, or a 1-piece wheel/hub assy ?
The only "knobby" tires I am aware of in that size are known as stud-tread.
Several of the site sponsors can probably supply what you seek.
  • Gtractor, 637Yeoman and Macmagee have said thanks
#3 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted May 27, 2017 - 10:18 PM
One piece I my measurement is three inches bearing to bearing.
#4 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,797 Thanks
  • 5,095 posts
Posted May 27, 2017 - 10:53 PM
You are missing a dimension.  Your title has no rim size.
Is it   "410/350-4" or "410/350-5" , or  "410/350-6" , or "410/350-8" ?  I Google'd that tire size and found all 4 of those rim sizes.
Also a picture of what you need would really help - even if you have to borrow one from the net..
Here is 410/350-6 from my stash as an example.
Best of Luck!
Edited by Gtractor, May 27, 2017 - 11:15 PM.
  • TomLGT195, 637Yeoman and Macmagee have said thanks
#5 Gtractor OFFLINE
Gtractor
  • 9,797 Thanks
  • 5,095 posts
Posted May 27, 2017 - 11:11 PM
Here is the "stud" tread Bruce is referring to.  This one happens to be a 410/350-6.
  • 637Yeoman and Macmagee have said thanks
#6 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted May 28, 2017 - 03:40 AM
Yes I left out the size it is five inch with 3/4 bearings thanks.
  • Gtractor and 637Yeoman have said thanks
#7 637Yeoman ONLINE
637Yeoman
  • 1,571 Thanks
  • 1,276 posts
Posted May 28, 2017 - 05:03 AM
By nobby tires, do you mean the kind, like what would be on a three wheeler?
#8 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted May 28, 2017 - 06:12 AM
The kind pictured in an earlier post why do you have something?
#9 637Yeoman ONLINE
637Yeoman
  • 1,571 Thanks
  • 1,276 posts
Posted May 28, 2017 - 10:29 AM
No i dont, just wondering what for.
#10 Macmagee OFFLINE
Macmagee
  • 30 Thanks
  • 67 posts
Posted May 28, 2017 - 02:14 PM
To lower the front end. I went to a pull yesterday and that what everyone was running.
#11 637Yeoman ONLINE
637Yeoman
  • 1,571 Thanks
  • 1,276 posts
Posted May 28, 2017 - 07:02 PM
You can use the same size, but that tread, altho commonly used, may not be your best bet. I would look for a good set of tri ribs, if it were me, but the studded tires, also work well.
