Wide 15" 4 Lug Wheels?
6 replies to this topic
#1 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 534 Thanks
  • 303 posts
Posted May 27, 2017 - 07:00 AM
I have looked high and low for a source for wide, 9~10 inch, 15" 4 lug wheels and have yet to find anything suitable with a 5" bolt circle. Can anyone recall any brands that used something similar?
Thanks,
#2 glgrumpy OFFLINE
  • 8,354 Thanks
  • 7,733 posts
Posted May 27, 2017 - 12:27 PM
You must have a MTD 990?  Some have changed hubs on them to mount 5-stud wheels, not sure if off little smaller units or where/what, but has been done. Usually to mount 12" wheels and find tires easier. Ask in the MTD forums here.
  • 637Yeoman said thank you
#3 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 534 Thanks
  • 303 posts
Posted May 28, 2017 - 09:44 AM
Pretty close, I need a set for my 999. Have a pair of 29X12-15 Goodyear's that need to go on it. May end up fabbing up an adapter and use 5 lug Ford wheels.
#4 Sawdust OFFLINE
Sawdust
  • 5,363 Thanks
  • 3,261 posts
Posted May 28, 2017 - 10:26 PM
The Wheel Horse 5 lug hubs with the 1 1/8th" axle holes work on the 990's. Problem is a few years ago you could get them cheap but now very expensive.
Edited by Sawdust, May 28, 2017 - 10:26 PM.
  • MolonLabe said thank you
#5 diesel nut ONLINE
diesel nut
  • 629 Thanks
  • 399 posts
Posted May 28, 2017 - 10:56 PM
How about an 8 lug rim off of some of the bigger farm tractors or equipment?  I know the rims on my Wheel Horse 1054 are from the right side of an International hay baler and the opposite side uses an 8 lug which is the same pattern as the 4 lug.                Stewart
  • Sawdust and MolonLabe have said thanks
#6 Cat385B ONLINE
    HAZMAT CAT
  • 13,138 Thanks
  • 9,617 posts
Posted May 28, 2017 - 11:55 PM
Rear rims from New Holland 1210/ Ford 1210 have that rim size, but with a 6 bolt set up.
#7 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 534 Thanks
  • 303 posts
Posted May 29, 2017 - 05:50 AM
Sawdust thanks for jogging an old man's memory! I have an 8 speed Uni-Drive complete with 1-1/8" hubs that has sat under a tarp for years out of view, I had completely forgotten about it. Time to break out the hub puller and order some 15X10" Ford wheels.
Thanks again!
  • Sawdust said thank you
