experimental alternative gardening
3 replies to this topic
#1 holdenboy1960 OFFLINE
holdenboy1960
  • 1852 Thanks
  • 985 posts
Posted May 27, 2017 - 06:36 AM
i am just learning and doing different things in growing herbs and small plants so this is what i'm doing atm ,
the poly pipe is 6 " x 10 ft post-62113-0-36598100-1495883764.jpg using a 205 litre ( Aust 44 gallon drum )drum as the main reservoir 1/2 " feed hose to the unit
post-62113-0-45579100-1495883828.jpg the float is out of an industrial gurney water tank  that's in this under poly tank , this water feed tube is 4ft long
 i used old hessian potato bag seams for the 2 wicks to draw the water from the bottom tute up into the top dirt filled tube post-62113-0-39191600-1495883857.jpg
the advantage of this is i can be away for a week and know the plants are still alive when i get back , the 2nd advantage is i can liquid fertilize instead of manual fertilizing as required  ,
i have 2 cherry tomatoes in atm and just planted 2 mint & 2 parsley but not up yet , i used cow poo and hay mulch for the fill, was lumpy so i put it all through the leaf, branch mulcher 1st , come out nice & chopped up fine
Shane
Edited by KennyP, May 27, 2017 - 06:42 AM.
Adjust Gravity
  • Alc, KennyP, oldedeeres and 2 others have said thanks
#2 KennyP ONLINE
  • 52518 Thanks
  • 53098 posts
Posted May 27, 2017 - 06:42 AM
Hope it works well for you.
#3 John Arsenault OFFLINE
John Arsenault
  • 3251 Thanks
  • 1432 posts
Posted May 27, 2017 - 07:00 AM
Seems like a lot of system for such a small grow space, are you planning on expanding it if it works out?
I have noticed with my container planting root space is a must for good results. specially for plants like tomatoes.
  • Alc, oldedeeres and holdenboy1960 have said thanks
#4 holdenboy1960 OFFLINE
holdenboy1960
  • 1852 Thanks
  • 985 posts
Posted May 27, 2017 - 07:31 AM
its working well so far , i am just trying the tomatoes as they need reasonable root space to be beneficial , if it works out good for me in majority i will expand ,
John your garden looks really healthy there , done well
 Kenny thank you for editing the pix for me as it always does it wrong on me
  • oldedeeres said thank you
