Got a pair of DB walk behinds to get back to working status.
26 replies to this topic
#16 Mudwallower OFFLINE
Mudwallower
  • 24 Thanks
  • 27 posts
Posted May 28, 2017 - 08:15 PM
Best I could do is get you pictures of my rims
That will work, or do look at the images in the first post and see if they are the same.  :D
#17 Mudwallower OFFLINE
Mudwallower
  • 24 Thanks
  • 27 posts
Posted June 30, 2017 - 03:51 PM
Well it has been a busy last week.
Got a Garden Plow, Cultivator, Sickle Bar, Disc Harrow, and a spare GP blade, but it has different mounting bolt pattern.  All from far out East of the Cascades. that is a nice dry environment resulting in just surface rust.
Found less than a mile away a tractor frame, gear box, with wheels.  So now have enough parts to probably get two tractors up and running.
Traded a four groove engine pulley for a Seeder that has the fertilizer tray rusted out at the bottom, so could use images and measurements of the tray to repair this one.  Missing the seed tray cover and of course the seed discs, so meed measurements of the latter and images of both.
From same fellow who traded me the Seeder, he gave me a Potato Plow 917.57550!
Does anyone have manuals on the Seeder and Potato Plow??
Edited by Mudwallower, June 30, 2017 - 05:08 PM.
#18 Alc ONLINE
  • 6,917 Thanks
  • 7,474 posts
Posted June 30, 2017 - 07:12 PM
Is it a DB seeder ? If so it should be the same box as on my TriTrac
#19 Mudwallower OFFLINE
Mudwallower
  • 24 Thanks
  • 27 posts
Posted June 30, 2017 - 11:17 PM
Yes, a DB Seeder. If you can put up some images that would be great!
#20 Alc ONLINE
  • 6,917 Thanks
  • 7,474 posts
Posted July 01, 2017 - 05:19 AM
If you go into the Implement forum and search David Bradley Garden Seeder & Field Planter there are many pictures and ones of mine
#21 Alc ONLINE
  • 6,917 Thanks
  • 7,474 posts
Posted July 01, 2017 - 05:21 AM
That was the Thread title which the pictures of mine where in
#22 Mudwallower OFFLINE
Mudwallower
  • 24 Thanks
  • 27 posts
Posted July 01, 2017 - 04:19 PM
Tried several searches in forums, home, gallery for "David Bradley Garden Seeder & Field Planter" with no luck....
#23 Mudwallower OFFLINE
Mudwallower
  • 24 Thanks
  • 27 posts
Posted July 01, 2017 - 06:53 PM
Tried "David Bradley Seeder", still no luck.
#24 Mudwallower OFFLINE
Mudwallower
  • 24 Thanks
  • 27 posts
Posted July 01, 2017 - 07:07 PM
 Looked at the Gallery thru your profile, found three results on a "Power King"....
Edited by Mudwallower, July 01, 2017 - 07:08 PM.
#25 Alc ONLINE
  • 6,917 Thanks
  • 7,474 posts
Posted July 01, 2017 - 09:34 PM
Strange I can't copy the link for you , try in the Implements fourm
#26 Alc ONLINE
  • 6,917 Thanks
  • 7,474 posts
Posted July 01, 2017 - 09:42 PM
http://gardentractor...der#entry464327
#27 Alc ONLINE
  • 6,917 Thanks
  • 7,474 posts
Posted July 01, 2017 - 09:44 PM
That link should work
  • Mudwallower said thank you
