I am going to rethink my keeping gas in the tank over the winter
21 replies to this topic
#1 junkyardjeff OFFLINE
junkyardjeff
  • 82 Thanks
  • 89 posts
Posted May 25, 2017 - 08:52 PM
My good Sears custom 10 was late getting used this year due to weather and a ignition problem,when I fired it up it really did not run too well and after adding some fresh gas and after a couple laps around the yard today it started running much better. Never had any problems before but there is always the first time and I usually have them going by late march or early april but it looks like the extra month was enough time for the gas to start going bad so I will drain all gas this winter.
  • Cvans, boyscout862, old coot and 2 others have said thanks
#2 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,368 Thanks
  • 4,078 posts
Posted May 25, 2017 - 09:04 PM
Don't really have a winter here, but with 5-1/2 machines, some don't get run as often as they should. I use a 5 gallon can and add 1 oz of the Sta-Bil 360, and 1 oz of Gumout All-n-One to the 5 gallons. (I use this mix to make a separate 40:1 2-Stroke mix) Everyone seems to like it. No complaints after sitting 6 months before a run. Both say they treat Ethanol.
  • Alc, oldedeeres, old coot and 1 other said thanks
#3 MiCarl OFFLINE
MiCarl
  • 1,647 Thanks
  • 880 posts
Posted May 25, 2017 - 09:05 PM
The reason I don't drain tanks is I'm worried about condensation and corrosion in the tank.  I store full with treated fuel.  Untreated modern gasoline goes bad very fast - especially if it's in an out building.  Or worse yet, outside.
Just put the boat in the water Tuesday.  Treated fuel has been sitting almost 8 months.  No problem.
If you do drain the tank I suggest laying down a coat of fogging oil to protect it.
Edited by MiCarl, May 25, 2017 - 09:08 PM.
  • Alc, HANKG and chieffan have said thanks
#4 chieffan OFFLINE
  • 8,365 Thanks
  • 5,788 posts
Posted May 25, 2017 - 09:09 PM
If you have a metal tank, condensation is a real possibility.  I keep the tanks full and treated with Sta-bil.  The carb gaskets can't dry out if there is fuel in the carb.
  • oldedeeres and old coot have said thanks
#5 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,684 Thanks
  • 1,148 posts
Posted May 25, 2017 - 10:15 PM
  I use non ethanol gas in all my small engines and my 63 year old outboard. The outboard is the only one with a metal tank and it gets emptied at the end of the season and the proper amount of two stroke oil poured in the tank for the proper mix in the spring to prevent rust over the winter. The carb is drained also. All the rest get the gas emptied out of the plastic tanks, started and run 'til they die. Been doing this for some yrs and no problems even with gaskets drying out. The outboard gas is run thru the snowblower and wheeler through the winter. To each his own.
                                               Mike
  • Alc, KennyP and oldedeeres have said thanks
#6 karel OFFLINE
karel
  • 1,822 Thanks
  • 1,210 posts
Posted May 26, 2017 - 03:20 AM
whenever I pick up an animal I plan on keeping for a while. I make it drainable.
#7 KennyP ONLINE
  • 34,187 Thanks
  • 43,306 posts
Posted May 26, 2017 - 05:42 AM
I use non-ethanol and Seafoam. Not any issues, even with last years 2-cycle mix.
  • John Arsenault said thank you
#8 HANKG ONLINE
HANKG
  • 5,826 Thanks
  • 3,197 posts
Posted May 26, 2017 - 06:09 AM
If you do drain the tank I suggest laying down a coat of fogging oil to protect it.  Yeah man, never had a problem with bad gas and keeping the tank full is key to eliminating condensation always kept my boat tanks full and stabilized
#9 LilysDad OFFLINE
LilysDad
    Oh, shoot!!!
  • 11,788 Thanks
  • 8,917 posts
Posted May 26, 2017 - 06:41 AM
>Now that I just got my new to me Ingersoll, I might just keep it in the living room next winter.<  Did I really just say that out loud? :watch_over_fence:
  • KennyP, old coot and MolonLabe have said thanks
#10 dodge trucker OFFLINE
dodge trucker
  • 1,882 Thanks
  • 2,491 posts
Posted May 26, 2017 - 07:27 AM
the only choice I have for non ethanol is the $6+ a quart stuff off the shelf of Lowes, etc.... a couple of places have the gallon jugs and they want $24.99 a gallon..... no thanks, I ain't payin 10x the price for non ethanol...
  • KennyP and old coot have said thanks
#11 SimplyRad OFFLINE
SimplyRad
  • 724 Thanks
  • 595 posts
Posted May 26, 2017 - 10:36 AM
Years ago I used to keep my motorcycle in the living room of my apartment during the winter.
  • old coot said thank you
#12 BTS OFFLINE
BTS
    Make Stuff Up
  • 3,748 Thanks
  • 2,206 posts
Posted May 26, 2017 - 10:59 AM
A week ago I filled up the car with gas and I also filled 3 5gal cans at a QT . I got home and dumped the gas in several tractors and noticed it smelled awful. My loader is even running a little rougher with this gas in it, luckily the car is still running OK. I would of thought being a super busy gas station their gas would of been fresher.
#13 lrhredjb OFFLINE
lrhredjb
  • 465 Thanks
  • 419 posts
Posted May 26, 2017 - 11:09 AM
Maybe their tank was low and you got some stuff that was floating near the top. After I got water in my gas by buying it at a low lying station after a heavy rain I tend to pick the higher elevation places now.
#14 LilysDad OFFLINE
LilysDad
    Oh, shoot!!!
  • 11,788 Thanks
  • 8,917 posts
Posted May 26, 2017 - 02:13 PM
And my wife told you to go do what?
#15 speedbird OFFLINE
speedbird
  • 256 Thanks
  • 135 posts
Posted May 26, 2017 - 06:04 PM
One year I got Some aircraft gas given to me and put in all the tractors and motorcycles, and come spring everything started up like it had been running last week. Floyd.
