lift table extension
3 replies to this topic
#1 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted May 25, 2017 - 08:37 AM
  I finally tired of putting push mowers on the HF lift table and on some not able to have all 4 wheels on the table. Looked through my scrounged metal and decided to use portions of some discarded wire display racks and some very light gauge 1" angle. Only has a screw at each end to hold it and it probably weighs only 2 lbs. I tapped the screw holes in the deck so I don't have to try to start a nut from underneath. I think it will serve the purpose well. I put a couple of screws in the wall to hang it on when not in use.
                                           mike
Edited by ol' stonebreaker, May 25, 2017 - 08:41 AM.
  • Alc, hamman, KennyP and 3 others have said thanks
#2 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted May 25, 2017 - 09:03 AM
If it works for you, then all is good! Nice extension.
  • ol' stonebreaker said thank you
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted May 25, 2017 - 09:44 AM
Necessity is the mother of invention
#4 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted May 25, 2017 - 11:54 AM
  I'm far from being a tree hugger but I try to utilize all the discarded iron I find simply to save $$.
                                    Mike
  • MFDAC said thank you
