Gilson tractor
5 replies to this topic
#1 vern OFFLINE
vern
  • 1 Thanks
  • 2 posts
Posted May 25, 2017 - 01:31 AM
I have an old gilson tractor, i have the dozer blade but have to make the attachment, if anyone has this I need a traceing of the linkage that has 3 holes and a long slot.  My tractor looks similer to the gear 16 that gilsonrunner1 posted on mar. 26 2017,
  • 637Yeoman said thank you
#2 boyscout862 ONLINE
  • 12,846 Thanks
  • 9,169 posts
Posted May 25, 2017 - 06:50 AM
Welcome to GTT. Check out our Manuals Section and allow people some time to reply with the info. Post some pics of the tractor and the plow. Good Luck, Rick
#3 Oldford OFFLINE
Oldford
  • 1,134 Thanks
  • 786 posts
Posted May 25, 2017 - 08:00 AM
Hi Vern is this the tractor yours looks like?
from this post... http://gardentractor...son-owner-here/
that's all i can help with... good luck in your search
#4 Lz1zjj OFFLINE
Lz1zjj
  • 1 Thanks
  • 2 posts
Posted July 23, 2017 - 11:29 AM
Hello GT talk. I have a Gilson 38 in, 11 hp engine lawn tractor. Model 52118. I am having a real hard time finding a v belt for the clutch/brake. Goes from engine to the rear gear box. I can not find the correct designed size anywhere. I am having issues shifting gears while cutting the grass. I have replaced the belt size a few times and I do not think I have the correct size. I have adjusted the brake, no change. I believe my belt is too tight and it does not unclutch properly with the tensioner pulley. Cont to drive and it does not release the belt tension
Any help much appreciated. 3 weeks of finding the solution
Thank you
#5 jimmy G ONLINE
jimmy G
  • 1,197 Thanks
  • 779 posts
Posted July 24, 2017 - 12:00 AM
The belt needs to be so loose that it would fall off without belt guides when breaking,go a size or two longer,there's a manual section here that might have what you need
  • Lz1zjj said thank you
#6 Lz1zjj OFFLINE
Lz1zjj
  • 1 Thanks
  • 2 posts
Posted August 17, 2017 - 09:22 AM
Bought a manual. Belt size is the following if anyone else needs it. v belt gilson 212931. Troy built equivalent 702171. 101" by 1/2"
