so whats the best way to get stuck in head bolts out. i have 2 that r gonna b a pain and i really dont want to snap them. ive unloaded a nice amount of wd on them, the heads of the bolts move but the rest doesnt, usually that means there gonan break.
best way to get head bolts off.
Started by
Guest_jdecker94_*
, Jun 16, 2011 02:58 PM
4 replies to this topic
#1
Guest_jdecker94_*
Posted June 16, 2011 - 02:58 PM
#2
OFFLINE
Posted June 16, 2011 - 03:06 PM
On bolts like this, I always rap them with a small hammer several times to jar the threads. Put your penetrant on, rap them a few times, then spray again. Do this several times an hour or so apart before attempting removal. Another good thing is to use an air impact, just a small 3/8" impact, & set it on it's lowest setting, so as nowhere near enough power to twist off the bolt. Just the mild impact action alone will many times get the bolt loose. I've had to run the impact on many for several minutes, then have the bolt come on out. But once you see the bolt begin to move, add more penetrant, run in reverse, the forward, then reverse....you will begin to get more movement each cycle.
#3
Guest_jdecker94_*
Posted June 16, 2011 - 03:37 PM
the one right by the exhaust manifold came out, but the other one snapped, i got the makita 18v drill and the cobalt bits out. it'll b half drilled out tonight.
#4
OFFLINE
Posted June 16, 2011 - 03:53 PM
If you have a welder handy, just weld a nut to the broken bolt and let it cool. Then it should back right out. The heat from welding will break the rust loose, and after I weld a nut on, I usually tap it a few times with a hammer.
#5
OFFLINE
Posted June 16, 2011 - 04:55 PM
It also helps to put heat on the head before attemping to remove the bolt, once it is pretty hot, rapp it a few licks and then let it cool off before trying to turn. Of course a couple shots of Blaster does'nt heart either.
