Aftermarket Carbs
14 replies to this topic
#1 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,975 Thanks
  • 9,618 posts
Posted May 23, 2017 - 12:13 PM
Have any of you had experience with the Kohler K 321, 341 carb copies offered on eBay?
  • Xrperry said thank you
#2 dtsh OFFLINE
dtsh
  • 234 Thanks
  • 159 posts
Posted May 23, 2017 - 12:25 PM
Not directly related, but I've used some of the knockoff B&S Flo-Jet carbs and they work OK, though the bolts and threads are metric. I would expect much the same for the Kohler knockoffs. The build quality on the ones I've seen are fair and on par with the originals.
  • boyscout862, LilysDad and chieffan have said thanks
#3 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted May 23, 2017 - 12:54 PM
Its really a 50/50 crap shoot, many of the screws will strip out if your remove the jets or idle screws, half of the ones I have gotten in leak gas which is why I decided to only sell OEM carbs unless a customer asks for a chicom one.
The ones under $20 are the real bad ones, nothing will match up to OEM carbs.
  • boyscout862 and LilysDad have said thanks
#4 dodge trucker ONLINE
dodge trucker
  • 2,298 Thanks
  • 3,014 posts
Posted May 23, 2017 - 05:14 PM
get what you pay for/ I'd rather take my chances rebuilding a (hopefully) good used core.
  • Bolens 1000 said thank you
#5 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,975 Thanks
  • 9,618 posts
Posted May 23, 2017 - 05:53 PM
Aren't used ones getting hard to find, especially #30?
Edited by LilysDad, May 23, 2017 - 05:53 PM.
#6 poncho62 ONLINE
poncho62
  • 1,601 Thanks
  • 1,612 posts
Posted May 23, 2017 - 06:04 PM
I got a carb from iSaveTractors....was about $60 + shipping......Its the smaller one for the K241, 301........It works real good.
I also got a Chinese knock off, its a #30 and was only $25 with free shipping....it took forever to get here, but I was in no hurry.....I havent tried it yet. I took the float bowl off and noticed that the float is plastic......will see how it works one of these days. The one on my K341 is working good right now, so it might be a while....lol
  • LilysDad and Diesel1050 have said thanks
#7 KC9KAS ONLINE
KC9KAS
  • 5,326 Thanks
  • 4,672 posts
Posted May 23, 2017 - 06:30 PM
One thing I noticed on the cheap carbs....you need to watch which way the choke cable operates the choke...some are "backwards" from the originals.
#8 Xrperry OFFLINE
Xrperry
  • 982 Thanks
  • 751 posts
Posted May 23, 2017 - 08:00 PM
I used 4 china made carbs so far and not a problem. You can get a carb for less than a rebuild kit.some lme carbs I rebuilt by the book didn't go well.as cheap as the carbs are that I used you can just toss it and buy a new one
  • LilysDad said thank you
#9 karel OFFLINE
karel
  • 1,990 Thanks
  • 1,330 posts
Posted May 23, 2017 - 08:17 PM
I've picked up a couple of briggs horizontals with the china flow jets on them recently. I threw them in a box. I just figured that was the problem with them. I hope I don't  never have to stoop that low, but them flow jet be getting scarce. so i'll hold on to them. they sure are pretty though, all new looking.
#10 Xrperry OFFLINE
Xrperry
  • 982 Thanks
  • 751 posts
Posted May 23, 2017 - 10:06 PM
I have about 15 large flojets in a box, they all leak at the gasket, yep warped.anyway to fix them
#11 karel OFFLINE
karel
  • 1,990 Thanks
  • 1,330 posts
Posted May 24, 2017 - 04:17 AM
I thought they leak at the jet seat, brass on pot metal? I have a couple of those on generators. so its ok if they leak out. as long as you have a gas tank with a petcock.
#12 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted May 24, 2017 - 05:44 AM
Tried a couple of the chinks except for the threads, no problem so far.
  • Alc and LilysDad have said thanks
#13 Xrperry OFFLINE
Xrperry
  • 982 Thanks
  • 751 posts
Posted May 24, 2017 - 08:15 AM
Mine leak where the halves screw together they didn't put enough screws in them
#14 Alc ONLINE
  • 6,744 Thanks
  • 7,397 posts
Posted May 24, 2017 - 08:54 AM
"Mine leak where the halves screw together they didn't put enough screws in them "
We're the screws missing or not a place designed to put them
#15 Xrperry OFFLINE
Xrperry
  • 982 Thanks
  • 751 posts
Posted May 25, 2017 - 07:16 PM
All the screws there, but under the idle mixture screw ? There is a square piece that kinda stick out ,that's where it leaks.have medium flojets same way.feeler gauged them and they are warped
