Restored John Deere Serial Number Tag
4 replies to this topic
#1 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted May 21, 2017 - 08:05 PM
Fellow member Don (Truck21) recently picked up a 1977 John Deere 208 and asked me if I'd be interested in restoring the serial number tag for him. He stated that it would be a challenge as it had been covered over by the previous owner with unknown layers of green paint. Well, after seeing the tag I accepted and immediately went to work on it. Here is what the tag looked like before taking it off of the tractor:
First thing I started to do was to remove the green from the raised lettering, the serial number bar, and outer perimeter edging, mostly to see how well the aluminum finish would be:
Once that was done and I was satisfied that the aluminum would finish out nice, I then started removing the rest of the green paint from the remaining tag. Wanting to determine how well the original black base coat would look:
After finding that the black base coat had too many scratches, I then decided to strip all of the base coat off down to the bare aluminum and start off with a new base coat:
Once the tag was stripped and cleaned, I started applying a couple of thin layers of new base coat:
The tag sat for a little while, not fully cured, but not tacky either. Here is where the fun begins. I use a flat head dentist pick and carefully start removing the unwanted black paint from the raised lettering, the serial number bar, and outer perimeter edging, just like I did above when removing the green paint. When all of the black paint is removed, I carefully shine up the exposed aluminum areas with a fine steel wool pad. When everything suits me and looks good, I then apply two coats of clear finish to the tag and do a little polishing. here is the tag after the two clear coats of finish.
  • tractorgarden, sacsr, WHdbJD and 5 others have said thanks
#2 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted May 21, 2017 - 08:07 PM
Not sure what happened, but if a Moderator is reading this, could you rotate the last three pictures for me. I don't know why they posted sideways like this.
Thank you!
Edited by johndeereelfman, May 21, 2017 - 08:07 PM.
  • truck21 and 637Yeoman have said thanks
#3 Kster526 OFFLINE
Kster526
  • 1,082 Thanks
  • 670 posts
Posted May 22, 2017 - 06:16 PM
Great job my friend. They should be using this for an article in the Lawn & Garden Mag.
  • MH81 and johndeereelfman have said thanks
#4 Canawler OFFLINE
Canawler
  • 1,951 Thanks
  • 1,806 posts
Posted May 22, 2017 - 06:27 PM
Better not do so good of a job on those. Next thing you know, a John Deere lawyer will be sending you a Cease and Desist letter. ;-)
#5 pacubcadet OFFLINE
pacubcadet
  • 58 Thanks
  • 56 posts
Posted May 23, 2017 - 08:37 AM
That looks simply amazing. I would never have the guts to do this to any of my serial tags
Sent from my iPad using Tapatalk
